| Home > Help Needed / General Tech Chat > crank question... | |||||||
15 Posts Member #: 10124 Member central scotland |
16th Dec, 2012 at 06:59:05pm
Ive had an old metro turbo moor under my bench for a few years now, and have just taken it apart as i need a crank for another engine, and i want a block for building up for the K100 16v head I also have.
16th Dec, 2012 at 07:51:49pm
On 16th Dec, 2012 baw-bag said:
Ive had an old metro turbo moor under my bench for a few years now, and have just taken it apart as i need a crank for another engine, and i want a block for building up for the K100 16v head I also have. my question is around the journals/shell bearings. on all a-series ive stripped before, the crank is shiny silver on journals and the nose and tail. this:-
this crank is different, - what I was expecting to be shiny-silver is more of a dull nickel colour! this:-
likewise the shells are not what I expected either - they dont exhibit any scoring and are a strange colour - the material isnt like any standard shell Ive removed before - here beside a set i took out of another motor i have apart:-
I have, like most people heard that some fabled turbo motors came with a treated crank - is that actually true? - how can i tell if this has had something done to it? thanks for any info. BB K100 is a 8 valve head. and it can be down to how its driven and looked after as well |
16th Dec, 2012 at 07:59:38pm
On 16th Dec, 2012 Chalkie said: Not necessarily
K100 is a 8 valve head. On 16th Dec, 2012 baw-bag said: Thats fucked
![]() Edited by Sprocket on 16th Dec, 2012. On 26th Oct, 2004 TurboDave16v said:
16th Dec, 2012 at 08:02:43pm
if the second pic is of the so called turbo crank then it looks like it has been hardened ,
16th Dec, 2012 at 08:05:22pm
yup, my K100 is a 16V - Late K100RS head.
16th Dec, 2012 at 08:09:28pm
thanks for that Carl - the turbo motor they came out appears to be low-mileage and generally in OK condition - damaged ring-lands excepted.
16th Dec, 2012 at 08:11:23pm
16th Dec, 2012 at 08:12:38pm
oh and a pukka turbo crank has a different part number to the run of the mill A+ crank On 26th Oct, 2004 TurboDave16v said:
16th Dec, 2012 at 09:07:03pm
yup, my K100 is a 16V - Late K100RS head. and yup, that crank is fubar - dont think it will grind out - some people shouldnt be allowed to drive cars. Why? You can grind 1mm. That removes a lot of scores... On 13th Jul, 2012 Ben H said:
