Home > Help Needed / General Tech Chat > How to put the hole in the head for bypass hose
topcat
Member #: 9408
Tiptree, Essex
Hi all, I have a bypass hose which I will be using, just wondering how to put the hole in the end of the head? Being on the end of the head is it possible to do with a mill?
www.topcatcustom.co.uk
Personally I would just mill a spot face (flat area) then drill/tap.
Two things to bear in mind,
1 - if you use the genuine Leyland/Rover stub it is the weird non-standard thread size same as the crank tail - taps are expensive.....
2 - where the hole enters the head casting waterway there is very little space before the other side of the casting so a normal taper tap may not fully cut the thread before it hits the other side and stops....
EDIT - I presume you are talking about the normal bypass connection, not dry decking or similar ???
Edited by Rod S on 17th Dec, 2012.
My head had a plastic bung in the hole for the bypass takeoff.
For dry deck ports, I believe Carl did mine on the mill. I now have a pillar drill with a rotating table, so could do it on there in theory.
topcat
Member #: 9408
Tiptree, Essex
Sorry I meant dry deck type bypass hose, the big one around 1" diameter!
I have a mill but not sure how I would hold a head on end as it would be a long way sticking up past a 90° angle block!
ado15
Member #: 9838
Or you could fit the spacer under the thermostat housing and plumb it to the bottom hose. Does exactly the same as the little bypass hose, just a slightly longer route.
Sorry, just re-read your last post......
Edited by ado15 on 18th Dec, 2012.
Steve
DSN Classics Ltd
www.dsnclassics.co.uk
Angle Grinder, get it nice and flat, 1" hole cutter. Then use RTV!
Piece of Piss.
Piece of Piss.
Copyright 2012 Tin Shed Engineering.
Ahem, mine hasnt leaked yet lol
The head that is not the tin shed...That leaks lol
topcat
Member #: 9408
Tiptree, Essex
I guess I could side mill a flat on the end of the head, then drill through to 25mm by hand or on a pillar drill, it's only got to be watertight after all!
Amp
Member #: 7856
On mine I clamped it on a 45 degree angle block and rotated the head 45 degrees, used an end mill to create a flat (granted I then flattened more than I wanted), and then drilled it in a pillar drill with a rotating bed!
I haven't tested it yet, but it looks alright!
