Home > General Chat > What a tool!!!
evad1980
Member #: 10165
Stansted, Essex
Just wanted to share my new toy with you. I read a post on here (can't remember who posted it) about rust removing and saw a reply from mr Fenton about a 'black and decker power file' that he brought.
As I had a fair bit of rust to remove I decided to get one.....
Well, wow!! What a bit of kit... This thing gets in all the real hard to reach places, I ain't done much to the mini recently cos of the cold garage and work commitments but managed to brave it this evening cos its an enjoyable tool to use. Any of you who need to remove rust or paint in awkward places then this is a must!!
Probably a pointless post but wanted to share!! Merry Christmas to ye all!!
That good info. Do you have a pic of it,?
its better than scratting your finger ends off
Steve you should get one of these they are ace. They are an electric version of a compressed air belt sander, approx 1/2" belt width.
Other advice I will give, for steel forget the cheapo red grit belts, they are no good wear out in seconds. You want the blue Zirconium/Aluminium oxide belts, more expensive but last ages.
Just don't get the cheepo belts. They are too long and often pop of as soon as you touch the metal.
evad1980
Member #: 10165
Stansted, Essex
I don't have a picture but click on the link below and you should see one...
http://item.mobileweb.ebay.co.uk/viewitem?...lassified=false
There are a couple of versions, I got the 400W one, it came with 3 different arms and several belts for around £50.. It's fantastic!
t@z
Member #: 452
Chester, UK
this? http://www.diy.com/nav/fix/power-tools/pla...0E-350W-9807053
www.twitter.com/lilpinkiy
Yes, but shop around as they can be bought for less than that.
Right that's on my list, thanks gents, have you a link for the belts Tom?
No, last lot I had made by an abrasives company in Sheffield me and a mate shared between us 100 belts.
I usually get them from ebay. just measure your old belts carefully and get the same length.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yes I got one after seeing a post from Mr Fenton, you'll find a million uses for it and decent belts can be had for pretty cheap.
On 7th Nov, 2008 Nic said:
naeJ
m
evad1980
Member #: 10165
Stansted, Essex
Yup.. Money well spent!
I'm going to apply to Black and Decker for a recommendation bonus!!!!
adrian
Member #: 2726
wakefield
Something else to add to my list. Thanks.
evad1980
Member #: 10165
Stansted, Essex
I think I should be entitled to half of that!!! *happy*
100ev8
Member #: 9138
wolves
3m belts are tops
http://www.fishfight.net/
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Machine mart for the blue belts to fit black & decker power file, the real cheap ones are no good snap in know time.. Alan
Main Build
Upgrade to Turbo
Is these the belts you boys are chatting about?
http://www.ebay.co.uk/itm/Zirconia-powerfi...=item5d469d07d3
Those are the ones I buy. They are decent quality and the correct length.
Callum
Member #: 10396
Stoke-on-Trent
Would you get away with these? A bit cheaper
http://www.abtec4abrasives.com/13mm-x-457m...rice-1901-p.asp
Edited by Callum on 11th Aug, 2014.
