Home > Technical Chat > Pully size
Rammie2000
Member #: 10190
belgium
Hi all I have been looking on the web for a boost calculator... And found out that I would need a pulley of 110 to 115 mm in diameters to get a eaton m45 charger down to 11.5 psi...
I have entered that a standard mpi cranck pulley is 178 mm in diameters engine is 1330 cc displacement of charger 770 cc
https://spreadsheets.google.com/spreadsheet...ader=true&gid=0
Is this correct??? Where the hell will I find such a size of pulley?
How much boost is advised to run? I will get the engine down to aprox 8.5 psi. And I will use it for street fun and casuall track days.
Rammie2000
Member #: 10190
belgium
Also I calculated that the charger will run a 10075 rpm at 6500 rpm engine speed.
Chalkie
Member #: 9764
Northamptonshire.
think its 15% reduction pulley you need to go to 11.5
Rammie2000
Member #: 10190
belgium
So instead of a huge pulley I need a smaller pulley? If I enter a 15 % smaller pulley( 55 mm) in the calculater it say ill run 40 psi! Owkey I guess that thing is not working...
jakejakejake1
Member #: 10010
Northants
The smaller the pulley on the charger the higher the boost you will run - I think he means a 15% reduction pulley will reduce boost by 15%, but the actual pulley itself will be bigger
Rammie2000
Member #: 10190
belgium
so is there a pulley / boost calculator i can trust? so i can calculate the correct pulley diameter for me?
