Home > Beginners Tech > Gearbox
kappa
Member #: 9854
Hounslow, Middlesex
Evening all,
I just want to find out, I had a look on the forum but cannot seem to find what I am looking for?
Basically I am building my turbo engine and wanted to find out can I use a standard 1275 Mini/Metro gearbox or should it be a Turbo metro one that I need? I want to run straight cuts in there with a X-Pin Diff, but this is when funds come available.
So can you please tell me, will I be ok to run a standard box for the time being? If so, as stated before, the standard box or the turbo box?
Thanks for all the help
Bobby
Yes mate they are all the same.
some good reading on this page=
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4724
Edited by madmk1 on 24th Dec, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
oh ok cheers for that info, I have a guy selling a box and diff, he has 2 options a 2.7 and 3.1 diff, which one would be a better option?
daveg79
Member #: 9579
Tadley, North Hampshire
Whilst mechanically the fit will be fine, I very quickly broke a standard box with my turboed 1293. I'd recommend being conservative on power and hard usage until you get those straight cuts in. Also, I'd go for a 3.1 diff, certainly over the 2.7. All depends what you want though, top speed or acceleration. I'm doing a rebuild at the moment and intend to plump for a 3.1 over a 3.4 as a compromise so I have a slightly lower RPM for cruising and hopefully don't run out of top speed when I do some of the larger track day events.
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970
kappa
Member #: 9854
Hounslow, Middlesex
What will give better acceleration?
What size wheels and profile tires are you using?
kappa
Member #: 9854
Hounslow, Middlesex
7 x 10's with 165 x 70 x 10's
Whats the planned usage?
For an everyday road car I would go for 3.1:1
For a weekend/track car a 3.44:1.
Also whats the planned power output? Standard helical boxes can be killed very quickly!
Why not look up exactly what will do waht for you:
http://www.guess-works.com/Tech/ratio.htm
kappa
Member #: 9854
Hounslow, Middlesex
That was a big help, I may go for the 2.7, as this better on 10's for top end speed and quite good on acceleration
It will take a lot of revs to get you moving
kappa
Member #: 9854
Hounslow, Middlesex
Well I managed to get both 2.7 and 3.1 now in the deal i just got, so may just go with the 3.1, which will probably be a better option, as I am not always going to be doing top end speed.
