| Home > General Chat > Carb throttle plate and cable advice guys??? | |||||||
27 Posts Member #: 10183 Member Bridgnorth |
28th Dec, 2012 at 07:32:46pm
Right so my home made cable bracket doesn't work the best.. Which is the best on the market as I've come across a couple now and as per I'm spoilt for choice! Do they all locate in the same area?? Also does it matter which cable you use with them?
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
28th Dec, 2012 at 08:40:57pm
which carb is it for a hif44? Done now needs redoing lol |
28th Dec, 2012 at 09:04:39pm
Yes sorry for the hif44 |
28th Dec, 2012 at 09:58:25pm
Why not just use a factory item ? 9.85 @ 145mph
28th Dec, 2012 at 10:44:58pm
Well searching and there are 3 carb brackets and none of those are like the one I had to replicate on mine (prob home made to start with) and pics I've looked at cant see which ones they are using?? |
29th Dec, 2012 at 07:17:59am
here you go standard hiff44 plate if you have a turbo carb this will be different
Edited by wng691s clubby on 29th Dec, 2012. Done now needs redoing lol |
29th Dec, 2012 at 09:20:56am
Thanks for that much appreciated, the home made one on mine just bolts on the one corner hence the movement in it. Does the cable need to be held anywhere else between the pedal and the carb or is it ok as long as not trapped by anything?
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
29th Dec, 2012 at 11:48:54am
That ebay one is a top quality product, I was chuffed when I bought one. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
29th Dec, 2012 at 12:50:58pm
Would this one do the trick or do u need the other one for the choke connection? Which is not connected.
29th Dec, 2012 at 12:53:42pm
thats the same as the top linc hiff44 hiff38 plate, choke and accel on same side Edited by wng691s clubby on 29th Dec, 2012. Done now needs redoing lol |
29th Dec, 2012 at 01:13:24pm
Cheers thanks for that |
