Home > General Chat > Never had this happen before
Had my nearside rear wheelbearing collapse tonight luckly i was only doing 40 odd and on a slight bend as it could have been nasty
its seized solid ive left a great darky 50 meters up the road and flatspotted the tyre
there was no warning no whining noise nothing
AA had to get it back
Could have been nasty ! Least it wasn't to bad and you got a free lift home ! *smiley*
evolotion
Member #: 83
Glasgow, Scotland
i'v had one lock up before, bu ti heard it rumbling, so about-turned and baby'd the car home, only for it to lock up a few miles from my house.. got rescued by teh AA.
Denis O'Brien.
I had a front nearside one seize once. Not nice as you have practically no control over the car.
The one I had go failed due to not enough grease in it I reckon, it was a set of hubs I got second hand and bolted on without checking them out first.
not good!
pack the new bearing in high temp grease wolfie
omiga 71 is the best in my book
if the new bearing wears out!???
it dont seize it lets you know
having said that its the rear ones we over look
with the correct lubrication
i have been guilty of that in the past
evolotion
Member #: 83
Glasgow, Scotland
lol should add that teh bearign that siezed was due to lack of grease too ... i had replaced it about 6 months earlier and i didnt put that much grease on it as i had no idea how much should be on it (was the 1st bearign i ever did) after that i properly packed bearings with silly amounts of grease, and never had a bearing fail since. that was ~3 years ago, ish. :)
Denis O'Brien.
well ive repaired the mini
seems the rear cylinder had been leaking and washed the bearing in brake fluid
Thanks goes out to dangerous who popped round mine with a whole good radious arm as the bearing had welded itself to the stub axle
cheers mate!
This guy had is bottom arm come loose last week at a Norwegian Minishow.
Might not look to bad, but remember we drive on the right side (pun intended) of the road.
Edited by Vegard on 16th Jun, 2005.
That happened to me in my old clubman - on the m25! dragged me accross another lane :(
