| Home > Help Needed / General Tech Chat > Idle problems | |||||||
5 Posts Member #: 10222 Junior Member |
1st Jan, 2013 at 07:25:12pm
I have a 1986 mini with a metro turbo motor, it has been rebored to 1293, it has an avonbar cam, 1.5 roller rockers, standard carb tho. The problem i have is that it wont idle at less than 2k, if i try to lower the tick over it seems like its hunting ( rev up/die/rev up/die and so on ) cant find any air leaks ! I was wondering if the carb needed jetting ? or do i need a different dizzy ? i saw an old avonbar cataloge and they were selling a specialist one, non electronic with vac. Any Ideas ? Any one ? |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
2nd Jan, 2013 at 07:43:28am
you say it has a standard carb do you mean non turbo hiff44? or the standard turbo carb? Done now needs redoing lol |
2nd Jan, 2013 at 01:25:40pm
Sorry standard turbo carb, thought maybe i needed to use a different needle profile. What distributor do you run ? |
389 Posts Member #: 9751 Senior Member Derbyshire |
2nd Jan, 2013 at 01:28:52pm
have you blocked off the PRV in the plenum? could that be leaking? |
2nd Jan, 2013 at 01:30:03pm
Whats the prv ? |
2nd Jan, 2013 at 01:32:38pm
The plenum has been modified to take a dump valve and also on the lower right side something has been welded up ( standard dump maybe ? ) |
2nd Jan, 2013 at 01:41:51pm
On 2nd Jan, 2013 mossy2a said:
have you blocked off the PRV in the plenum? could that be leaking? There must be an air leak, favorite place for them is the part-throttle lean off pipe. also, using 1.5s with the avonbar cam won't be helping. 1.3s will work better. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jan, 2013 at 07:45:16pm
I was going to refit the 1.3s just to try it. Can someone post a pic or diagram of the carb Pipe work please ? Which is the part throttle lean off pipe ? What about the electronic module on the side of the dizzy how should this be wired ? |
2nd Jan, 2013 at 08:37:22pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=217478
