Home > Help Needed / General Tech Chat > n/a glowing center branch
eden7842
Member #: 8852
leicestershire
As title on a 1380, mg cam and weber 40.
Any ideas as too why?
Eden
ministef1
Member #: 1791
Cranleigh, surrey
mixture probably...
"Cars are a lifetime of pain"
jakejakejake1
Member #: 10010
Northants
Has it always done it or just started?
I suspect the timing is out, retarded ignition timing can cause a hot exhaust.
eden7842
Member #: 8852
leicestershire
Just started. . . . . . Just put the weber on
too lean, timing too far retarded etc. get it setup.
eden7842
Member #: 8852
leicestershire
Ah I thought it was advanced that would cause it to run that hot. Easy fix then.
Il go tweek
Only the middle? My old mg metro lumped mini used to glow abit after a hard ragging or is this on idle
eden7842
Member #: 8852
leicestershire
This was idle, only middle. As that dealing with 2 cylinders. Anyhow. .
Sorted, static 22 degrees tweek of the weber and it runs like a champ. Just gota fix the slipping clutch that the weber has caused.
Cheers guys. Great help *smiley*
Get it on the rollers for a tune. Mine always glows though even though its set up correctly
