Home > Help Needed / General Tech Chat > valve springs binding!!!
lil stu
Member #: 837
rugby
Hi guys,
I just refitted my cylinder head along with a new 1.5 rocker shaft. I already had a Kent 286 fitted.
I got given the double springs so I don't know the specification of them.
What springs should I fit to avoid them binding?
I'm really hoping I don't have to send the shaft back
Any help would be great, cheers guys
mossy2a
Member #: 9751
Derbyshire
Have you fitted any centralising washers at the base of the springs?, if not speak to Benross, I think he has made some.
These keep them apart.
Edit : I may have misread the post, if the coils are binding I.e bottoming out then you obviously need to change the springs or review your setup, thus my above statement is bollocks.
Edited by mossy2a on 4th Jan, 2013.
nick1275
Member #: 1615
Ferndown, Dorset
i had this issue (assuming yours bind on full compression), the kent website tells you which springs suit the cam and order them up.
only thing is unless you have an account with them, so they advised me of a company up north to place the order with, unfortunatly i cant remember there name
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
lil stu
Member #: 837
rugby
Yeah its the coils bottoming out, I will check out the Kent site then.
Phone Rich at Mini Spares North, he'll sell you what you need.
lil stu
Member #: 837
rugby
The site recommends springs VS2. Which mini sport have got for 50 squid. (Just the first place I looked).
I think I remember reading somewhere that Kent cams where designed to be ran with a 1.5 rocker, could someone confirm this? I just don't want to buy more stuff then find its never going to work
In general, Kent cams work well with 1.5. And should work well with your setup.
Surely that's down to the individual cam and it's intended use?
lil stu
Member #: 837
rugby
I feel VERY STUPID!!!!!
I was trying to turn the engine over without adjusting the rockers.
Thanks for the replys, and sorry for waisting your time.
That will teach me for panicing.
Stu
