| Home > Help Needed / General Tech Chat > import tax | |||||||
62 Posts Member #: 10154 Advanced Member Taunton, somerset |
5th Jan, 2013 at 06:21:32pm
5th Jan, 2013 at 06:55:05pm
Just call customs. Anything over £26 will have import tax calculated against declared or applied value I believe. Own the day
21 Posts Member #: 9396 Member |
5th Jan, 2013 at 07:14:37pm
hello there,
5th Jan, 2013 at 08:01:40pm
Thanks for the replys, works out pretty much the same to order from trigger wheels then. |
5th Jan, 2013 at 08:26:14pm
Also remember that all tax applied is for the total cost INCLUDING postage On 26th Oct, 2004 TurboDave16v said:
225 Posts Member #: 3772 Senior Member Wigan |
5th Jan, 2013 at 08:41:44pm
your only other option for zero tax is to get them to send it as a gift then its tax free. |
5th Jan, 2013 at 09:01:24pm
google it mate, shout take you to import tax site and it can calculate it Yes i moved to the darkside |
5th Jan, 2013 at 09:14:08pm
Don't forget that some delivery firms also add around another tenner on as a fee for paying the duty for you. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
5th Jan, 2013 at 09:52:16pm
Having just run the gauntlet of importing a car from teh States, import duty is 10% of the declared value and the VAT is charge at 20% on the declared value, the import duty and the shipping cost !
Metric is for people who can't do fractions. |
![]() 270 Posts Member #: 69 Senior Member Coventry |
5th Jan, 2013 at 11:02:24pm
10% on the value plus shipping vat on the whole lot, get them to declare it as a gift of a sample of no commercial value if you can... |
5th Jan, 2013 at 11:14:57pm
On 5th Jan, 2013 mini.cooper998 said:
your only other option for zero tax is to get them to send it as a gift then its tax free. Completely and utterly wrong. If it has value, it is liable for tax. Simplez. And IMO DO NOT use USPS/Parcel Force. It may seem cheaper, but postage is slow, and when it gets here, any cheapness goes out the window when Parcel Force stick their arm in and extort another £13.50 handling fee from you, and you wont get your goods until you pay them !! FedEx every time. 9.85 @ 145mph
5th Jan, 2013 at 11:16:38pm
That doesn't always work - tried it with an expensive piece of jewellery and HMRC actually impounded it and phoned me to collect before allowing it to be delivered.
5th Jan, 2013 at 11:19:13pm
On 5th Jan, 2013 Alex said:
Having just run the gauntlet of importing a car from teh States, import duty is 10% of the declared value and the VAT is charge at 20% on the declared value, the import duty and the shipping cost ! Robbing gits... Import duty varies depending on the gods. Most motoring related stuff is 3.5-4.5% and then of course our wonderful 20% VAT, plus any handing charges. So really the Import duty for automotive stuff is no big deal, but cunt is the VAT. Some goods carry zero import duty, but they are few. And as you said. There are many ways to try and get around paying the duty, Very often they will work, but you need to be prepared to explain yourself if things do go tits up, and they will hold your goods until it is resolved. 9.85 @ 145mph
5th Jan, 2013 at 11:32:28pm
Import duty is only charged if the declared value is over £135 including shipping, and it is waved if the amount of duty is less than £9. Import duty rates vary depending on the item. |
6th Jan, 2013 at 11:09:00am
On 5th Jan, 2013 metroturbo said:
Import duty is only charged if the declared value is over £135 including shipping, and it is waved if the amount of duty is less than £9. Import duty rates vary depending on the item. Any goods over £18 are liable. Unless it has changed very very recently. ( ie it hasnt ) Apparently any "gifts" from one individual to another less than £36 are ok. Over £36 they are liable. Although a gift posted from a business will of course look a bit susipicious Some good info about half way down this page http://www.sloanefox.freeserve.co.uk/importukduty.htm 9.85 @ 145mph
6th Jan, 2013 at 04:30:17pm
VAT is liable above £15 (or £40 if a gift), import duty above £135 as I stated above but waived if below £9 is due. http://www.hmrc.gov.uk/customs/post/buying.htm Unless HMRC are wrong (i.e. they aren't)
6th Jan, 2013 at 05:23:09pm
On 6th Jan, 2013 metroturbo said:
VAT is liable above £15 (or £40 if a gift), import duty above £135 as I stated above but waived if below £9 is due. http://www.hmrc.gov.uk/customs/post/buying.htm Unless HMRC are wrong (i.e. they aren't) But if you read your own link, you still pay VAT - that is the killer, not import duty. "All other goods If you order or send purchased goods other than alcohol, tobacco, perfume and toilet water from a country outside the EU then you: don't have to pay Excise Duty may have to pay Customs Duty on goods with a value that exceeds £135 will have to pay import VAT on goods with a value that exceeds £15" Try the last line...... " will have to pay import VAT on goods with a value that exceeds £15" VAT and handling charges are the killer, not import duty. Even the £15 loophole (used to be £18) is being closed down for imports from the Channel Islands (typically DVDs / CDs /BluRay). From the US you are screwed for VAT, end of story. Schrödinger's cat - so which one am I ??? |
6th Jan, 2013 at 06:13:55pm
I know VAT is due above £15, as I stated that? I was just trying to point out that there is also import duty to consider which might be important if you are comparing cost in UK against importing. As the cost of a single Megajolt is likely to be below the £135 threshold, and if it's close it is likely to be below the £9 limit so it probably won't figure at all. There was also mention of 10% import duty which may be the incorrect percentage as it isn't a flat rate, so I was trying offer some clarity on the minefield of what importing ends up costing. |
6th Jan, 2013 at 06:23:51pm
Yes, but the import duty (if it's required and as you say the threshold is quite high), is insignificant compared to the VAT.
6th Jan, 2013 at 06:35:14pm
I should probably add that in terms of how Customs actually apply their own rules for non-EU countries, for everything I've imported above the limit - with customs forms properly completed, not just marked "gift" - my results are approximately,
6th Jan, 2013 at 07:00:55pm
It's because we have the Queen on some of our currency and stamps... :)
On 6th Jan, 2013 Rod S said:
I should probably add that in terms of how Customs actually apply their own rules for non-EU countries, for everything I've imported above the limit - with customs forms properly completed, not just marked "gift" - my results are approximately, Canada - never charged out of eight times. Australia - charged once out of four times. USA - charged every time. Maybe the USA just hate me :) |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
7th Jan, 2013 at 01:16:43pm
I didnt get charged any import tax or anythign for the MJ I bought from USA
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
