| Home > Help Needed / General Tech Chat > BMW k1100 engine head removal | |||||||
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
5th Jan, 2013 at 08:12:06pm
I have recently purchased cheaply a low milage complete engine to relieve it of it's cylinder head. I have tried to unbolt the head from the block and can't loosen the head bolts. I don't want to force any thing with a long leaver bar, I was wondering if the head is bolted down through the block to the bottom end? Or just into the deck of the block as per mini.
5th Jan, 2013 at 08:20:43pm
Its just the head bolts.
5th Jan, 2013 at 08:42:01pm
Thanks, there domed Torx bolts,do you suggest I try one of those impact devices that you hit with a hammer to shock and loosen them?
5th Jan, 2013 at 08:53:30pm
I'd just use the correct 1/2" drive bit and a 36" breaker bar. if they round off then, you'll be drilling them out anyway On 26th Oct, 2004 TurboDave16v said:
5th Jan, 2013 at 09:23:16pm
that the good thing about torx/ allen heads... theres something to centralize the drill! On 28th Aug, 2011 Kean said:
