| Home > General Chat > Anyone making sensor bracket for trigger wheel? | |||||||
62 Posts Member #: 10154 Advanced Member Taunton, somerset |
5th Jan, 2013 at 08:48:15pm
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
5th Jan, 2013 at 08:55:18pm
i would love to know this as well, as i need the same thing |
5th Jan, 2013 at 09:54:56pm
If you can't find 20 quid, make your own. They really are simple to knock up. http://www.twin-turbo.co.uk
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
5th Jan, 2013 at 10:21:22pm
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
5th Jan, 2013 at 11:04:15pm
Thanks for the replies. Easy enough to make. Does it have to be in a certain place? Or just as long as its a few mm from the wheel? |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
6th Jan, 2013 at 09:53:26am
hi tom fenton on here makes the bracket and machines the pulley.
6th Jan, 2013 at 11:19:52am
On 6th Jan, 2013 lee.pb said:
hi tom fenton on here makes the bracket and machines the pulley. just got one off him and are of a very high quality and prompt turn around. well worth there money and sure other members will agree. yes but hes struggling to spend £20 on one from trigger wheels so carnt see him getting one from tom rick |
6th Jan, 2013 at 03:20:12pm
How much was toms one? also need trigger wheel.
6th Jan, 2013 at 03:57:05pm
So long as it is close to the wheel that is all that matters. You then need to move the missing tooth on the wheel relative to the sensor. If you have machined the teeth into the pulley then you do need the sensor in a specific place.
On 5th Jan, 2013 bodgins said:
Thanks for the replies. Easy enough to make. Does it have to be in a certain place? Or just as long as its a few mm from the wheel? http://www.twin-turbo.co.uk
1300 Posts Member #: 829 Post Whore essex |
6th Jan, 2013 at 08:34:05pm
the bracket that tom makes are top class 1293 Turbo mini
6th Jan, 2013 at 09:19:03pm
tom's are £100, this includes bracket and machined trigger wheel.
6th Jan, 2013 at 10:03:53pm
tom's are £100, this includes bracket and machined trigger wheel. well worth the money. +1 Yes i moved to the darkside |
327 Posts Member #: 1145 Senior Member North Wales |
7th Jan, 2013 at 11:03:37am
DSN CLASSICS might be anble to help to help you out??? ENG3305-S |
