| Home > Help Needed / General Tech Chat > fuel return theory. | |||||||
831 Posts Member #: 908 Post Whore gateshead |
5th Jan, 2013 at 11:30:48pm
if someone (ie me) had decided to put the fuel return line back into the fuel feed line instead of the tank, after the pump, what would it do to the regulator??
balls to the blower!!!
5th Jan, 2013 at 11:38:22pm
You can put it to the pump suction without a problem. If you put it after the pump you will have no return flow at all as pump discharge pressure will be higher than return pressure. |
5th Jan, 2013 at 11:48:23pm
it will cause a problem the return has to go to a low pressure point on the fueling system Yes i moved to the darkside |
5th Jan, 2013 at 11:57:28pm
what will happen is you will over power the regulator and it will force its way into the carb,
6th Jan, 2013 at 12:35:10am
it wont split the regulator diaphragm since the pressure will be the same either side, since the pressure is the same either side of the diaphragm there is no regulation and the fuel pressure will rise to what ever the fuel pump can sustain, which will be considerably higher than the desired 3psi. high fuel pressures have been known to overcome the float valve in the carb and flood the engine, which is the initial problem being suffered by this engine. On 26th Oct, 2004 TurboDave16v said:
6th Jan, 2013 at 09:09:34am
You're both half right.
6th Jan, 2013 at 09:11:55am
On 6th Jan, 2013 Sprocket said:
it wont split the regulator diaphragm since the pressure will be the same either side, since the pressure is the same either side of the diaphragm there is no regulation and the fuel pressure will rise to what ever the fuel pump can sustain, which will be considerably higher than the desired 3psi. high fuel pressures have been known to overcome the float valve in the carb and flood the engine, which is the initial problem being suffered by this engine. um ,colin, i may be drivelling here , but if there is 9 million psi fuel pressure on the underside of the diaphragm ,and engine manifold ref pressure on the uppper side ,how can the pressure be the same on both sides ? have you connected the fuel return to the upper side of your regulator ? if so do you find the pressure a little high too ?
6th Jan, 2013 at 09:36:34am
thought as much. will commence on re plumbing it all back in correctly. i fully expect the diaphragm to be fucked so will rip it apart and have a look. its amazing how something can just puzzle you for weeks, then all of a sudden, in the middle of asda, it comes to you! thank you everyone. balls to the blower!!!
6th Jan, 2013 at 11:00:37am
I'd be more concerned about dumping litres of fuel into the engine !!!
6th Jan, 2013 at 12:46:16pm
And dont crank it over with the plugs out and the ignition on !
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
6th Jan, 2013 at 01:29:23pm
you wont know until you put it back together correctly mate, but as above remove the plugs , dont crank it over with a live supply to the plugs give em hell |
6th Jan, 2013 at 02:23:27pm
ha ha. too late, already did that last week! it wasnt spewing fuel in massive amounts into the engine though. not enough to spray out of the plug hole anyway! it did fire up, but then cut out after a couple of seconds. balls to the blower!!!
