| Home > Help Needed / General Tech Chat > rasing the boost | |||||||
269 Posts Member #: 396 Senior Member sheffield/rotherham |
14th Jun, 2005 at 09:08:59pm
how is every1 rasing the boost im kinda confused how you guys are doing it, as the standard ecu is limited to 7psi, i understand that if u remove this and place a bleed valve it can be increased yes. but bleed valves aint exactly an accurate way to raise the boost. is it possible to use a boost controller to raise the boost on a metro turbo engine? if so how? speed is the best rush i have ever had!!!
14th Jun, 2005 at 09:12:21pm
I think 99% of us use bleed valves, we don't have any problems On 15th May, 2009 TurboDave said:
14th Jun, 2005 at 09:13:58pm
how do u make sure u dont apply too much boost jimster?as i hear the sligtest turn of a bleed valve increases boost more than ud think? speed is the best rush i have ever had!!!
14th Jun, 2005 at 09:15:17pm
I've not really found that, on my bleed valve, about 1/4 turn is 1psi, so quite easy really On 15th May, 2009 TurboDave said:
14th Jun, 2005 at 09:18:15pm
oh rite spot on ill give that ago, just alot of people i know as soon as i mentioned bleed valve there words was NO NO NO NO. speed is the best rush i have ever had!!!
14th Jun, 2005 at 09:19:47pm
you need to use a good quality boost guage so you can see how much boost you are running, once youve set it a few times you soon gert used to it no longer a series, but still 1.3 turbo.
14th Jun, 2005 at 09:21:47pm
rite cheers lad's bleed valve it is then. speed is the best rush i have ever had!!!
14th Jun, 2005 at 09:24:59pm
the sensitivity of boost via a bleed valve is all down to how much load there is on the acuator.
14th Jun, 2005 at 09:34:52pm
yesi understand what u mean mate speed is the best rush i have ever had!!!
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
14th Jun, 2005 at 10:13:41pm
i think people hear horror stories about bleed valves from typically your old turbo 'hot hatch' motors because people keep opening them up, and opening them, and bingo BANGo your engine/turbo pops
14th Jun, 2005 at 10:27:12pm
can i adjust the boost up and down by using the bleed valve as from what sum1 has told me the fueling and timing would be one if i adjusted it up and down all the time? speed is the best rush i have ever had!!!
244 Posts Member #: 34 Senior Member |
14th Jun, 2005 at 10:40:46pm
The safest way is to get it setup on a rolling road to a sensible level depending on your engine spec.
14th Jun, 2005 at 10:45:39pm
im gunna b using lamba sensor mate, just a friend of mine has a starlet turbo and he is able to have incar boosting and his fuel adjusts to the boost he runs speed is the best rush i have ever had!!!
