| Home > Help Needed / General Tech Chat > ok, now i think its the carb! | |||||||
831 Posts Member #: 908 Post Whore gateshead |
9th Jan, 2013 at 08:59:10am
can someone help me by telling me how to set the mixture screw correctly. i thought it was screw right in, then back it off 2 turns? that correct? sorted out the fuel pipework now and got 3.5psi going into the carb ok. pressure still holds with the pump off too and can see fuel in the jet so the float seems ok. if i pour a little fuel into the carb it will fire straight away, but wont with the dashpot fitted.
balls to the blower!!!
9th Jan, 2013 at 09:11:05am
What you have done will get you started. But you will need to adjust it further.
In the 13's at last!.. Just |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
9th Jan, 2013 at 12:23:14pm
You need to set the jet height so it is flush with the bridge (dashpot off) and then screw down 1½-2 turns.
Metric is for people who can't do fractions. |
9th Jan, 2013 at 03:54:42pm
will try both of them. thanks for the help.
10th Jan, 2013 at 07:18:40pm
tried both of them. no joy. poured some fuel into the carb dashpot hole and refitted the dashpot. it tried to start, then just kept turning over.
10th Jan, 2013 at 07:30:41pm
take dashpot off so you can see the jet and block / kink the return line briefly with the pump on fuel may well squirt out the jet, ( you could wind the fpr right in to increase the pressure)
Yes i moved to the darkside |
