Home > Help Needed / General Tech Chat > piggyback ecu?
lanxter
Member #: 396
sheffield/rotherham
is it possible to get a piggyback for metro turbo lump to plug into the ecu?
if so where from?
thanx
mark
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
no. listen to what everyone will tell you and throw away the ECU from the metro turbo, all it achieves is to limit boost pressure to 4 psi in the mid rev range, while allowing 7psi the rest of the time.
Chuck it away, and use the pipe that went to it to connect in a bleed valve to raise the boost to 7psi all the time.
Metro Turbo ECU is a waste of time!
lanxter
Member #: 396
sheffield/rotherham
i know mate but i wanna run more than 7psi and would like to be able to change my boost so i dont have to have it on high boost all the time.
So use a bleed valve then. Open=more boost, shut=low boost as limited by the wastegate actuator.
lanxter
Member #: 396
sheffield/rotherham
yeah im gunna do that now tom, sorted it out thought by using bleed valve method from what people had said i had to run high boost all the time. but has been explained to me now.
thanx :)
piggyback ecu? youve been spending too much time with the japanese
lanxter heres one
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...mMakeTrack=true
well worth the sheckels!
lanxter
Member #: 396
sheffield/rotherham
yeah most of lads i knock bout own japanese motors such as starlet turbos
id love a starlet turbo, if only i could find one for a couple of hundred beans
lanxter
Member #: 396
sheffield/rotherham
his is fully stripped using a hybrid turbo and lots of other engine mods is running bout 200bhp.
quick car for what it is
i saw one at combe that was stripped, cossie intercooler, and 1.2 bar of boost that was eating EVERYTHING on the track, ie evos scoobys skylines
lanxter
Member #: 396
sheffield/rotherham
hehe, yeah thats bout rite hes using a cossie front mount they cheap as chips off ebay.
eats alot of things round our area.
let me have a drive other month and was quickest car ive ever drove by a lnog shot.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Ive got an MBC that ill sell, its nicer looking than that one too just pm me if you want it
