| Home > General Chat > how long do your daily driver tyres last? | |||||||
10th Jan, 2013 at 02:13:42pm
Clio has just been mot'd advisory for all four tyres, now the rears have done over 23,000 and fronts 17,000. Its the first year i havent had to replace tyres mid year (normally have budgets so dont care) now with the clio i put premium tyres on the front, made driving alot nicer and felt alot safe too but the ware rate is rather quick.
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
10th Jan, 2013 at 02:17:19pm
going to replace my F&R as they will both be on the limit by 29k, done the whole swapping over half way as well. |
10th Jan, 2013 at 02:27:18pm
I got 8-10000 a set in my BMW. It always wore them evenly front and rear which was a surprise. The Cupra is looking like 7000 for fronts but probably 12000 for rears.
10th Jan, 2013 at 02:34:04pm
The route to my work are shit massivly pitted and full of pot holes wich i know wears them out alot quicker but also driving style has a huge impact. I do like the occasional traffic light rumble as does the misses. Drives
10th Jan, 2013 at 02:35:43pm
Rears about 26k front still going strong after the same amount of Miles.
Edited by gr4h4m on 10th Jan, 2013. I run a supercharger and I don't care the TB is on the wrong side.
10th Jan, 2013 at 02:38:30pm
I normally get 30k plus from my commuter. Current tyres are Avon and have done 15k and still look new. The rears were on it when I got it and I have done 25k since then and they have loads of life left. The car is an MG ZR. I think my drive to work is quite tyre friendly though. Only a couple of roundabouts and it is always busy so not to much arsing around. http://www.twin-turbo.co.uk
10th Jan, 2013 at 03:00:24pm
looking at it, I got about 23k from the fronts and 28k on the rears; running michelin pilot sports. Having just thought about it, i'm pretty happy with that although it is still a full set of boots a year. (A6 quattro). I'd be delighted if i was only paying £130 a corner
10th Jan, 2013 at 03:06:54pm
15k fronts and 30ish k on the rears
10th Jan, 2013 at 03:17:58pm
10th Jan, 2013 at 03:24:47pm
I have 7 roundabouts tight corners and some dualcarage way then tight offramp to a roundabout lol the pass side has worn more than the drivers side but also i found using renaults recomended pressures the tyres wear as under inflated on the rear fronts i have run at 34psi and the outers still wear more than the middle wtf is up with that? Renaults guide is 30at the front and 28 on the rear they look underinflated at that psi. I have been thinking about avons or falcons Drives
10th Jan, 2013 at 04:06:10pm
front tyres will generally wear the shoulders quicker/more than the rears.
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
10th Jan, 2013 at 05:47:34pm
my dad and i run michelin energy tyres reasonably priced last about 30-35k on the front and rear
Edited by munnracing on 10th Jan, 2013. |
1391 Posts Member #: 1686 Post Whore Oxford |
10th Jan, 2013 at 05:58:41pm
I run a mini as a daily on a539`s.
OMG Robert that's a big one |
10th Jan, 2013 at 06:11:31pm
Vauxhall Insignia Estate 60k (surprisingly!!!!!) rears, 28k fronts, Car currently on 86k with new shod on the front week before Christmas.
![]() 178 Posts Member #: 10196 Advanced Member |
10th Jan, 2013 at 06:22:36pm
Believe it or not i had a car that did 50k on tyres and i only replaced them cause the tyres were aging, they still had plenty of tread, they were michelin's, only criticism were they werent particular great tyres and were terrible in the wet. |
10th Jan, 2013 at 06:28:38pm
I currently done about 1200 miles on my rears and about same left Yes i moved to the darkside |
10th Jan, 2013 at 07:18:03pm
Not a daily, but the front A048's on my mini need replacing after less than 500 miles :)
In the 13's at last!.. Just |
10th Jan, 2013 at 07:49:44pm
wow, some seriously low mileages there !
10th Jan, 2013 at 08:21:33pm
I dont think ive had a normal car to get that sort of miles out of a set of tyres.
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
11th Jan, 2013 at 07:07:57pm
berlingo works van 12000 miles front 24000 rears, but it does get the shit kicked out of it on sites bad roads etc give em hell |
11th Jan, 2013 at 07:40:48pm
I think my Audi will be due a set of fronts by 17k If something is worth doing, it's worth doing half of. |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
18th Jan, 2013 at 10:11:20pm
You lucky sods
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
19th Jan, 2013 at 11:55:17am
about 40k front and rear on Pirellis fitted to Seat Ibitha,but I do drive like an old man LOL 'Where does the engine go?' |
149 Posts Member #: 9991 Advanced Member lichfield ,staffordshire |
24th Apr, 2013 at 06:18:21pm
ib done 3k on my mini and the front outer edges are torn to shreds, need to get a bit of negitive camber i think |
24th Apr, 2013 at 08:03:22pm
On 24th Apr, 2013 05bwardl said:
ib done 3k on my mini and the front outer edges are torn to shreds, need to get a bit of negitive camber i think Or tracking set?? |
jk
