Home > Help Needed / General Tech Chat > welding help arrrr
adrian
Member #: 2726
wakefield
Does anybody know of anyone local that's a reasonable price that can do the welding on my mini? About 3 years ago I bought a new wing to put on and a Clarke mig but never attempted it. The wing, front bulkhead crossmember where the subframe mounts, patch on boot floor, possibly an a panel and im sure a couple of other bits need attention.
Adrian in sunny wakwfield :
wng691s clubby
Member #: 9252
Cleethorpes
give it a go on some practice sheet metal you can only get better
Done now needs redoing lol
Keith Timson (his mk1 is on here somewhere) hadn't held a welding torch before he started that project and now it is a thing of beauty.
get stuck in - its the best way to learn and you'll never look back once you can weld yourself
mercenary62
Member #: 9937
get a mate or relative to show you what to do ,then keep practising on scrap metal till you think your ready to have a go on your mini pannels ,if i was near you id come over and get you started mate
give em hell
adrian
Member #: 2726
wakefield
It's the getting started and knowing wot to do thts slowing me. At uni i welded 10 inch with a mig which is me welding experiance.
mercenary62
Member #: 9937
doesent your local colledge do night courses in welding ,bodywork,etc
give em hell
Me and john did an evening bodywork course at wakie college over at cas. It was spot on to get me going and not expensive.
Also have a good read on www.mig-welding.co.uk lads of good beginners guides on there.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Getting your wire speed right is key. No matter what power setting....you will here a crisp sound when its right. Too low you'll get blobs of metal every where....too high you will have lumps of wire sprouting! The more confident you get, the higher the power/voltage you can go for. :)
On 19th Jan, 2010 wil_h said:
you want it to sound like bacon frying in a pan.
