| Home > Help Needed / General Tech Chat > dump valve selection | |||||||
336 Posts Member #: 9941 Senior Member Derby |
10th Jan, 2013 at 07:58:49pm
hi guys im in the process of building a turbo engine over the next couple of months but im wanting to avoid the usual dump valve woosh noise lol if possible that is! Im going to be hoping for the 170bhp mark! Is there one on the market i could have that would be suitable? i have heard some say a recirculating dump valve is quiet but i was speaking to someone else who had one on a car i had been in and it was far from quiet!
10th Jan, 2013 at 08:19:11pm
i have a bosch recirculating one - you cant hear it. was only 99p from ebay too |
87 Posts Member #: 9698 Advanced Member Pembrokeshire, Wales |
10th Jan, 2013 at 08:33:46pm
i have a Bosch recirc on my audi S2 (standard fitment) and with standard air box very quiet...
10th Jan, 2013 at 08:39:34pm
hmm i have got one of the plastic bosch ones off a saab will this do?
10th Jan, 2013 at 09:54:58pm
Probably |
10th Jan, 2013 at 10:06:00pm
thats what i use... |
11th Jan, 2013 at 09:28:01am
It may not be suitable for high boost as I've read somewhere on here? |
11th Jan, 2013 at 04:12:11pm
On 11th Jan, 2013 Johnny said:
It may not be suitable for high boost as I've read somewhere on here? There is a specific Bosch unit that is suitable. It has a thicker diaphragm and stronger spring. I have the part number somewhere, but in general, the standard items are up to the job, since those using them on big hp engines talking about big boost are talking about figures most on here go no where near. On 26th Oct, 2004 TurboDave16v said:
11th Jan, 2013 at 05:51:13pm
Ah i see. Thats good to know, i think mine was a bit leaky (may have been a bit worn) i was running 1bar of boost |
11th Jan, 2013 at 07:11:04pm
My plastic Saab one leaks too, on boost over 12psi.
11th Jan, 2013 at 07:53:06pm
Are you both sure you have yours plumbed in the correct way?
710Ns hold boost better and last longer than 710Ps, take this as friendly advice from someone who has probably sold/installed over 2 tousand pairs of 710Ns in the last 5 years
Some TM like minded people here >>> http://www.s4biturbo.com/art-dvtests2.php On 26th Oct, 2004 TurboDave16v said:
11th Jan, 2013 at 10:46:59pm
I was under the impression that the port oposite the small inlet manifold take off is connected the the plenum, and the side port connects back into the inlet. Am i wrong? This is how i did it on my car, it can be heard 'dumping' when you give it some stick. |
12th Jan, 2013 at 11:03:05pm
It may not be suitable for high boost as I've read somewhere on here? my Audi is 20psi with no problem with bosch recirc and they are used to over 30psi on more tuned (6-700bhp) audi 5pot turbos only thing they do is run 2 of them as the volume of air is too great for 1 of them when using the gt35/40r turbos.. so they more than up to job for a small 12-16psi 150-170bhp a series |
51 Posts Member #: 10080 Advanced Member Holland, Eindhoven |
13th Jan, 2013 at 10:27:17am
Still a question about the dump(bypass)valve of a supercharged engine. Is there something so I could manage my goal of pressure?
13th Jan, 2013 at 03:52:00pm
On 11th Jan, 2013 welshdan said:
I was under the impression that the port oposite the small inlet manifold take off is connected the the plenum, and the side port connects back into the inlet. Am i wrong? This is how i did it on my car, it can be heard 'dumping' when you give it some stick. They work both ways, but apparently one way works better than the other, and is less likely to 'leak' On 26th Oct, 2004 TurboDave16v said:
13th Jan, 2013 at 04:01:53pm
On 13th Jan, 2013 Bill said:
Still a question about the dump(bypass)valve of a supercharged engine. Is there something so I could manage my goal of pressure? I dont want too much pressure because of dailydriver. Any dump valve on a supercharged engine without a throttle infront of the supercharger, needs to be able to flow all the air the supercharger can pump at maximum speed, and that is a lot of air! As for boost control or limiting boost, a dump valve can be used to limit boost by bleeding off excess pressure. Using a bleed vlave MBC or boost controller in a similar way as you would with a turbo waste gate On 26th Oct, 2004 TurboDave16v said:
13th Jan, 2013 at 06:28:14pm
Good info, cheers. Im changing my engine and plan to run more boost in the next couple of months. What would a sign he that one of these is leaking? Would it be that a certain boost threashold could not be reached? Cheers,dan |
14th Jan, 2013 at 05:20:27pm
Well learn something new every day, my recirc valve is seemingly plumbed in the wrong way according to the diagrams!
14th Jan, 2013 at 06:10:38pm
Mine too LOL 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jan, 2013 at 07:03:15pm
same here....as said seems to work ok. |
15th Jan, 2013 at 09:51:20am
Standard OEM install....
15th Jan, 2013 at 05:27:57pm
I can see the reason why it is installed as standard that way round, on the cam belt cover Edited by Sprocket on 15th Jan, 2013. On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2013 at 05:39:54pm
On 15th Jan, 2013 Sprocket said:
I can see the reason why it is installed as standard that way round, on the cam belt cover ![]() I guess you are right - when Ford and the others OEMs who were messing about with turbos on possible/actual production cars back in the late 80's, early 90's they probably asked Bosch what they could supply for them.... and then installed it backwards..... Just think about how a diagphram valve works.... Schrödinger's cat - so which one am I ??? |
15th Jan, 2013 at 06:13:27pm
Lets agree to disagree, but before we do, consider this. Under boost, one way acts as a check valve, holds boost better, with boost and spring pressure forcing the valve into its seat, while the other way relies on the spring only to hold the valve shut on its seat............ Edited by Sprocket on 15th Jan, 2013. On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2013 at 07:34:59pm
Colin,
