Home > Technical Chat > T3 oil feed restrictor
mini118118
Member #: 10069
Hi guys can anyone tell me would a standard T3 with 360. Thrust bearings require a restricted oil feed.
I was going to buy one of those oil feed kits off eBay but was worried that would I need a restricted type or not. Or is the fact that the outlet from the block is not that high flowing anyway..thanks
I wound never restrict an oil feed to a non ball bearing turbo like the t3,
check the engine oil pressure first, it should be about 50 psi 60 absolute max.
welshdan
Member #: 1111
s wales
I didnt plan on using one...
