Home > Technical Chat > Estimated BHP and sugested clutch
mini118118
Member #: 10069
Hi guys what BHP would you estimate for a 1380 turbo 11cc powermax, morspeed super squish head 27cc chambers, Kent kc500 or MG metro cam, hoping to run around 15psi with intercooler, straight cut box
And therefore what clutch would you recommend, Pre verto..
Thanks
what turbo?
should see 140 hp+ with a good intercooler.
I would not recomend a preverto for a turbo lump anymore unless its a race car where you need somthing really light. the way forward is to pull a pair of verto's apart and stack the springs two deep, you get a better feeling clutch with much more torque capacity, and longer life from the crank thrusts, also it'll be self adjusting.
mini118118
Member #: 10069
T3 turbo.....ok I was thinking of using a lightend jobby!!!
its possible to get away with a Preverto orange plate at that kind of power, and a grey or double grey will definatly hold that power, but personally I dont like them, as on the pre verto you get all the force of the clutch springs pressing on the crank thrusts, which is about 900lb for an orange pressure plate and over a ton for the grey and double grey...
on the verto set up you get approx 1/3rd of the clutch spring pressure on the crank thrusts.... for a verto with two springs this is around the same as a std pre verto, a much better situation.
for the verto's you can get light steel outers, there is a cast one from mini spares, or an even lighter billet one from MED, the MED one will get you down to about the same as a pretty light aftermarket preverto, but there are the ultra light bilit pre verto's from swiftune, MED, SH etc whouch are too light for the road IMO.
mini118118
Member #: 10069
Thanks for the info Joe
no probs,
informed decision is a better decision *happy*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
You feel more of a man pushing down on a grey!
On 19th Jan, 2010 wil_h said:
Yeah and you get a gangsta style limp when you get out the car
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Time for these pups to man up!
You won't look so hard when your pushing the car back onto the trailer and going home early because the clutch has destroyed the crank thrusts *hehe!*
My RTS is as heavy as the grey it replaced :)
I've shown you the fix for this! *tongue*
are your pins well greased ?
oh and joe , where is your head !!!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Spoil sport, your just not feelling the love! *happy*
Having a temporary cash flow issue.... called christmas...
Just given it all an overhaul. The pins weren't round anymore :)
Should be better now.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
how about drill n tap the thrusts for an oil feed?
If it were me, where possible (and it is possible) i'd rather fix the problem rather than the symptom *wink*
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i agree already having a pre vert setup nd being a tight ass im going for the cheep option lol if i had my chance again id go RTS
Edited by Turbo This.. on 15th Jan, 2013.
