Home > Technical Chat > Turbo Carb question
mini118118
Member #: 10069
I ve got a carb a JZX1611 (BDD needle fitted) came fitted with a turbo and plenum, looking about there seems to be some confession is this a Merto turbo Carb. Reading about I can see a FZX1411 Mentioned.. If its not does anyone know the difference, it's a 1"3/4 HIF44.. many thanks
Already posted on " theminiforum "
It look identical to the FZX1411
mini118118
Member #: 10069
Haynes manual states FZX1411 or FZX1435.. What SUs are you guys using..the 1611 has the dash pot seal and valve in the butterfly????
