Home > For Sale > Updated list of stuff.
I also have an excellent condition set of 1275 drops with 2 new bushes fitted to the primary gear. The primary gear will need reaming to size before fitting. For sale as I fitted the bushes and then just bought a set of straight cut drop gears. £30
Standard 998 drop gears. £10.
1275 crank. Perfect std journals. Tiny bit of fretting to the top of the taper. Can be put straight into an engine £40
Standard a plus diff with output shafts £10
STD 1275 main and big end bearings. £20 posted each set. Or both for £35.
James
Edited by minimole23 on 20th Feb, 2013.
