| Home > General Chat > how tight | |||||||
306 Posts Member #: 7107 Senior Member essex |
19th Jan, 2013 at 07:35:50pm
hi guys how tight should the engine be to turn over by hand once big ends and mains are torqued up
19th Jan, 2013 at 07:38:26pm
rings can do this a bit,
19th Jan, 2013 at 07:48:53pm
thanks ill give it a go |
19th Jan, 2013 at 08:04:08pm
Check you have your mains caps on the right way round and on the right rods On 11th Feb, 2015 robert said:
19th Jan, 2013 at 08:19:26pm
yeah all in the right place ill check what joe said and see how i get on |
19th Jan, 2013 at 10:00:44pm
if the crank spins on its own freely, give all the big ends a wiggle, if they move on the journals then its just the tension in the rings On 26th Oct, 2004 TurboDave16v said:
20th Jan, 2013 at 12:22:25pm
Like the lads say, do one at a time,
20th Jan, 2013 at 12:44:16pm
right ive undone to outer pistons and it turned freely so tried the caps on the opisite rods and it just locked as soon i nipped them up so put them back nipped up and still turns ok but as soon as there torqued its tight to turn ? the crank has just been reground to +20big end +30 mains should i have the two journls messured again |
20th Jan, 2013 at 01:01:37pm
check you have the correct sized bearings on the big ends. On 11th Feb, 2015 robert said:
20th Jan, 2013 at 01:26:23pm
will do as they could have been packed wrong i spose |
20th Jan, 2013 at 02:01:38pm
bearings are the right size so all thats left now is to have the crank looked at ? |
20th Jan, 2013 at 03:15:11pm
Have come across a bent crank before. I would get it checked to avoid tears later |
20th Jan, 2013 at 04:02:45pm
yeah gona take it back this week and get the guy who done the regrind to have a look over it for me |
20th Jan, 2013 at 05:28:10pm
Have you plastigauged the journals?
20th Jan, 2013 at 05:44:25pm
Give it good turn over by hand, as many times until you are bored.
20th Jan, 2013 at 05:57:07pm
check the rods are the right way round, they are offset, On 28th Aug, 2011 Kean said:
20th Jan, 2013 at 06:04:12pm
yeah rods are in the right way and want turn it over to much a ruin the nearing im just gona have the crank re messured |
58 Posts Member #: 10226 Advanced Member Grantham, east midlands |
20th Jan, 2013 at 07:17:01pm
It just sounds to me like the caps are mixed up on the rods, I had same problem so torqued the crank up then the rods one by one changing caps around if it locked up until I could have all four tightened up moving freely. You'll find it'll just be one giving you jip. |
20th Jan, 2013 at 08:31:27pm
First thing to check, make sure the crank in the rods is the correct way round, so the little end of the rod isn't thrusting against the side of the piston.
