Home > Help Needed / General Tech Chat > Wheel cylinder choice
T3Tone
Member #: 252
Sunny suffolk
What bore rear wheel cylinders will give the least amount of braking??? No matter what i try my rear wheels lock up under hard braking. I have 7.5"discs up front and all my brake lines and hoses are new so theres no problem of a blocked/kinked brake line not allowing fluid to return freely.
So is it bigger bore cylinders or smaller to reduce the braking force at the rear??? I know there are at least 5 different bore sizes to choose from so ive got quite a selection.
Oh and i adjust up the rears so the shoes are just skimming on the drums and the handbrake adjusted so 4 clicks locks the wheels, so these should'nt be causing the problem.
Many thanks,
T3tone.
-MINI CLUBMAN 1380 TURBO-
I have a brake bias valve installed, it's great, you can adjust the breaking for the MOT, everyday driving and the track, all without getting out of your seat. Highly recomended
T3Tone
Member #: 252
Sunny suffolk
cheers mate, could this be fitted with a diagonally split system??
WTF are you still running one of them systems for? Seriously - buy a pipe kit from the specialists and re-do the lot like it should be done - Then you can also run a rear bias valve or the smaller cylinders...
ps - you need a smaller bore slave cylinder to reduce the pressure...
http://www.gr8website2.com/calverst/articl..._bias_valve.htm
http://www.gr8website2.com/calverst/articl..._adjustment.htm
T3Tone
Member #: 252
Sunny suffolk
Did'nt realise there where any real gains from changing to f/r split system mate!!!
Agree with Dave, junk the diagonal b*llocks and pipe it up so it is a front to rear split. Then as Jim says get an in-line brake pressure reducing valve and you can increase and decrease front to rear bias to your liking. I used to add a bit more rear bias when "having a go" round some lanes, or I used to remove some rear bias when it was bloody slippy out and about.
T3Tone
Member #: 252
Sunny suffolk
Many thanks for advise gents:) swopping to a f/r split system it is.
