| Home > Help Needed / General Tech Chat > Piston bore clearance | |||||||
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
20th Jan, 2013 at 02:58:28pm
20th Jan, 2013 at 03:37:50pm
What you see and measure at the crown can mean nothing.
20th Jan, 2013 at 04:30:02pm
A Stevie says, clearance at the crown isn't really meaningfull as some pistons have masses of clearance above the top ring.
20th Jan, 2013 at 05:07:54pm
So, good news then regarding the clearance at the top of the pistons.
20th Jan, 2013 at 05:07:58pm
Another double post, bloody ipad Edited by dazibee on 20th Jan, 2013. |
20th Jan, 2013 at 06:04:29pm
piston clearance should be measured at the bottom as in the pic below.... if its mesured under the gudgeon pin it will be different,
Edited by Joe C on 20th Jan, 2013. On 28th Aug, 2011 Kean said:
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
20th Jan, 2013 at 06:45:02pm
Daz if MED machined the bores and supplied the pistons as they are with mine then your good to go mate. |
20th Jan, 2013 at 06:52:43pm
On 20th Jan, 2013 Joe C said:
piston clearance should be measured at the bottom as in the pic below.... if its mesured under the gudgeon pin it will be different, 9 though at the top isn't suprising, in fact thats tighter than a lot i've seen. a lot of people leave forged pistons baggy as they are suposed to expand a lot with heat, modern forged pistons are pretty good so this isnt the case so much these days,
20th Jan, 2013 at 07:01:53pm
thats 18, but tbh its not unexpected,
20th Jan, 2013 at 08:38:42pm
4 thou sounds good to me, if thats the clearance measured the way joe has shown, and not at the crown of the piston. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Jan, 2013 at 12:29:26am
I put the Accralites in at 0.002" clearnace as the bore grows as it 'breaks in' but as Joe says, modern materials and manufacture of forged pistons don't require such large clearancies as they used to.
Edited by Sprocket on 21st Jan, 2013. On 26th Oct, 2004 TurboDave16v said:
21st Jan, 2013 at 05:54:38pm
On 21st Jan, 2013 Sprocket said:
One thing appears to be apparent with MED, they like to run their engines with a baggy fit when their cranks bearing clearancies are sized near double as well! A respected engine builder said to me recently better too loose then too tight when I queried him about a clearance that seemed a little large. Which while maybe not optimum will at least make sure nothing binds up. On 7th Oct, 2010 5haneJ said:
27th Jan, 2013 at 09:33:19pm
So.. Now happy with the clearance at the top of my pistons, tis normal. Regarding the actual skirt clearance, I spoke to a guy at Omega the other day who said for my pistons I need a bore size of 71.12 mm / 2.800 in. Bought myself a dial bore gauge and measured my bores to be 71.1238 mm or 2.80015 in, 1.5 thou larger than Omega specified. Hope this will be alright. Edited by dazibee on 27th Jan, 2013. |
27th Jan, 2013 at 10:07:28pm
That'll be absolutely fine. +or- 20/30 degrees C would see a difference of a thou in bore. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Jan, 2013 at 08:00:18am
0.15 thou? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jan, 2013 at 10:11:49am
1.5 tho as its .80015 the last digit is going into 10ths. Edited by matty on 28th Jan, 2013. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 293 Posts Member #: 10010 Senior Member Northants |
28th Jan, 2013 at 12:07:26pm
Isn't .80015 equal to 800.15 thou? |
28th Jan, 2013 at 12:20:13pm
0.0 .......... Tens
28th Jan, 2013 at 06:35:36pm
On 27th Jan, 2013 dazibee said:
So.. Now happy with the clearance at the top of my pistons, tis normal. Regarding the actual skirt clearance, I spoke to a guy at Omega the other day who said for my pistons I need a bore size of 71.12 mm / 2.800 in. Bought myself a dial bore gauge and measured my bores to be 71.1238 mm or 2.80015 in, 1.5 thou larger than Omega specified. Hope this will be alright. my omega's went in at 2.800 and that gave me 2.5 thou skirt clearance according to my notes and there is 2.5-3 thou noted on there too, i had to chase around MED/ OMEGA when having my block honed as my machine shop had the arse on so i assume this is the med/omega recommended clearances also my notes say the crown is 70.45mm dia that gives about 26thou clearance @ the crown edited because the [-][/-] strike through does not seem to work Edited by Brett on 28th Jan, 2013. Yes i moved to the darkside |
29th Jan, 2013 at 10:05:56pm
I wrote this down wrong. My bore measured at 2.8 inch plus 1.5 thou. So this is 2.8015 inch or 71.16mm. Sorry for the confusion
So.. Now happy with the clearance at the top of my pistons, tis normal. Regarding the actual skirt clearance, I spoke to a guy at Omega the other day who said for my pistons I need a bore size of 71.12 mm / 2.800 in. Bought myself a dial bore gauge and measured my bores to be 71.1238 mm or 2.80015 in, 1.5 thou larger than Omega specified. Hope this will be alright. |
