| Home > Technical Chat > engine calculated | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
20th Jan, 2013 at 09:19:03pm
so i took the time to calculate my engine. (060 overbore)
20th Jan, 2013 at 09:25:09pm
I dont like to see pistons a long way from the deck, mine are 5 thou down. On 28th Aug, 2011 Kean said:
20th Jan, 2013 at 10:05:42pm
On 20th Jan, 2013 Joe C said:
I dont like to see pistons a long way from the deck, mine are 5 thou down. na engines i tend to build fluch but do not see how to lower compression otherwise (do not wont to use a decompressionplate) and do not know how much more the head can have. although i will work the head out first so the more i can get there the less piston to deck i take) is there a other better way to lower compression? maybe machining out the pistons to 10 cc dish (if possible) you can do anything if you set your mind to it...
20th Jan, 2013 at 10:22:34pm
its possible to machine the pistons, ad quite easy to do,
21st Jan, 2013 at 07:27:12am
just need to find a good machine shop in belgium then. (not many you can trust here or want to do an effort for just 4 pistons) you risk that they put them in a lost corner and loose them or let them machine by a new person to see what he can do.... but it would indeed be better to make a bigger dish. did not know those pistons could have so mush taken of. learning allot on this forum. (and to say that i am seen as a mechanic on the Belgian forum... am good with na engines and twin carb setups though but always hi compressed much easier to raise it than to lower it i see now) nice mini by the way
Edited by Rammie2000 on 21st Jan, 2013. you can do anything if you set your mind to it...
21st Jan, 2013 at 07:58:45am
easy enough to get another couple of cc's in the head On 11th Feb, 2015 robert said:
21st Jan, 2013 at 11:25:32am
so if i set the pistons fluch ( 0.15 mm down) i have the option to kep 6.5 cc diched piston but then i have to make the head go to 33cc (what seems big but should be possible i thinck) making 8.61 cr.
21st Jan, 2013 at 11:37:01am
28cc seems to be the normal maximum you can get easily whilst leaving the beak in the chamber. On 11th Feb, 2015 robert said:
18th Feb, 2013 at 09:13:42pm
looked in to pulley and i am not a math scientist but here it is.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
19th Feb, 2013 at 07:31:54am
Rammie,
Edited by Yo-Han on 19th Feb, 2013. Dazed and Confused.... |
19th Feb, 2013 at 09:44:38am
19 years ago I just whacked 6mm off the top of the pistons to lower the CR. Not ideal by any means, but certainly never caused any problems. hat was factory pistons with a huge top ring land area.
Edited by stevieturbo on 19th Feb, 2013. 9.85 @ 145mph
19th Feb, 2013 at 08:56:22pm
You guys probably right about those to much calculating from my behave but it is a expensive build so do not want to build something that gos bang ore something that lacks power. but going to look at nuukuus threat to get more inspiration. you can do anything if you set your mind to it...
