| Home > Help Needed / General Tech Chat > arp rod bolt torque? | |||||||
22nd Jan, 2013 at 12:09:32pm
What should they be torqued up to when not using the the arp lube?
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
22nd Jan, 2013 at 12:51:11pm
buy some arp lube. If something is worth doing, it's worth doing half of. |
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
22nd Jan, 2013 at 01:29:55pm
if you just search there product code on there website its all there. have them at home and dont with me atm otherwise i would look |
22nd Jan, 2013 at 05:53:03pm
You need to use the correct lube otherwise the torque needed will differ.
In the 13's at last!.. Just |
22nd Jan, 2013 at 07:32:33pm
Would the torque setting not be std as per heynes manual?thats what i did mine to... |
22nd Jan, 2013 at 08:02:46pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4607
22nd Jan, 2013 at 08:08:29pm
On 22nd Jan, 2013 welshdan said:
Would the torque setting not be std as per heynes manual?thats what i did mine to... Nope. It's much less than standard. In the 13's at last!.. Just |
22nd Jan, 2013 at 11:01:08pm
imo either buy the lube or buy a stretch gauge
Yes i moved to the darkside |
28th Jan, 2013 at 08:05:48pm
I just came across the instructions for mine so thought I'd update this.
28th Jan, 2013 at 08:38:34pm
http://arp-bolts.com/instructions/206-6002.pdf On 26th Oct, 2004 TurboDave16v said:
29th Jan, 2013 at 11:17:27am
On 28th Jan, 2013 Sprocket said:
http://arp-bolts.com/instructions/206-6002.pdf thats the bad boy i was looking for. was down when i tried the other week |
30th Jan, 2013 at 12:33:04am
I did mine to 35 with lube so should all be good |
