| Home > Help Needed / General Tech Chat > more heads than i tought | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
22nd Jan, 2013 at 05:05:42pm
hi guys. been sorting my mini stuff to move everything to an other location for the 9th and hopfully last time (3 mini's an estate and 3 truckloads of interiors and parts) but annyway whille i was sorting i noticed that i have 3 12g9... heads with what seem to be big valves (nearly touch each other in the center) and 2 of them have very big inlets and outlets. than i have a 4th 12g... head with smaller valves but this one has locator rings (metro i think) and than i have the longmann head who i was planning on using for the charged engine...
22nd Jan, 2013 at 05:54:22pm
Best head to use will depend on what you're using it for. Tell us more. In the 13's at last!.. Just |
22nd Jan, 2013 at 06:04:55pm
measure the valve diameter, look for double springs, look for any number stamped near the thermostat housing.
22nd Jan, 2013 at 08:00:39pm
its for a 1330 that i want to supercharge with a blow trough setup (i know i know superchargers........ )
22nd Jan, 2013 at 08:03:36pm
22nd Jan, 2013 at 08:26:55pm
serious?? than all the boost calculators on the web are shit crap.... (used 20 of them to calculate what pulley size i needed some says the same) than there is no need to go at 8.5cr? 9 cr will be low enough than. shit 7 is low... it just happens that i was given an eaton and turbos are so daim expensive over here (and more complicated in my eyes) and there are no supercharged minis in belgium yet
On 22nd Jan, 2013 apbellamy said:
7psi max on the m45 you can do anything if you set your mind to it...
22nd Jan, 2013 at 08:43:02pm
You can run 12psi, but any more than 7 and they just make heat. Seen a few people that make slightly more power with 7psi than 12.
22nd Jan, 2013 at 08:50:25pm
thats why i was happy with the eaton... i thought if it can give boost to a 1600 cc engine it will give good boost to a 1300 cc engine (and like a said it came from a mate of me who works in a bini garage) if i decide not to use it i will go turbo. (something small so i cant over blow the engine) you can do anything if you set your mind to it...
22nd Jan, 2013 at 10:16:16pm
bit off topic but this was what the exel sheat came up with... so this is bullsh....?
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
22nd Jan, 2013 at 10:57:43pm
Are you sure about the 2000ft? |
23rd Jan, 2013 at 08:58:22am
when developing the amd cooper s , it ran up to 15 then 17 psi , power went up to a max of around 250 bhp .this with the original eaton blower. the kit settled on 15 psi ,with the amd pulley . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
23rd Jan, 2013 at 09:06:07am
no thats not exact but avarage atmos pressure is (i live near the coast at sea level) you can do anything if you set your mind to it...
