Home > Help Needed / General Tech Chat > Mpi body, SPI loom, carb engine. I need help!!!
Jack2eaton
Member #: 9772
Sheffield
Hi guys right let me explain the situation 1st of all.
The body is from my original mpi motor I have pretty much completed all other mods to get the turbo arb up and running an am at the stage of the re-wire. I currently have the mpi wiring in place as it was with mpi motor. However have been informed that that I a very tricky procedure to convert for carb use.
I have been told that it might be an idea to replace this with an SPI loom. Would others agree?
If not I'm open to any suggestions.
If that is the case or not, what mods will I need to make to either loom to feed the new carb set up.
Like I say I haven't started any wiring mods so am open to any suggestions and would like to hear everyone opinions on the best way to go about it.
Cheers in advance, Jack
welshdan
Member #: 1111
s wales
Just sent you a pm. A carb loom might be easier to start with if you cqn get one. I used spi as it was already fitted to the car, dan
welshdan
Member #: 1111
s wales
i believe that the mpi ecu controls more that fueling/ignition in the mpi car. the spi ecu only does the ignition ande injection side of things. as you are replacing the injection with carb that should be ok. either remove or tape into the loom the injection plugs etc.i traced and removed the ecu and ignition wires. you will also come across the 'switched live' which will be needed when wiring in megajolt. basically the injection stuff is unplugged and replaced with the carb, the spi ignition wiring/gubbins is removed and replaced almost directly with the megajolt. the fuel pump etc still worked on mine, so did everything else on the car, apart from the rev counter (which will work once you have wired it into the megajolt). its a case of working your way through and removing the unwanted wiring (ignition part) from the spi loom. it didnt take long and was more straight forward that i thought it might be.
Edited by welshdan on 23rd Jan, 2013.
