Home > For Sale > Garage clearout a few parts
retro-racer
Member #: 7907
Thame, Oxfordshire.
Clearing out and renovating my garage/workshop/storage unit ready for my new projects. So looking to sell all my no longer required parts and spares. I will put all prices inc P+P however would welcome collections.
Will add more to list as I find them.
I have some new parts as well so I will list the new parts first and the used parts second.
Most bought from minispares so I will put the part numbers at the end in brackets for anyone to look them up on the MS site for a full description.
• Pair of genuine rover door step repair panels (BHM13) £ 50
• Set of 8 standard brand new cam followers (2A13) £ 12
• Set of AE STD 998/1098 crank thrusts (AEW2122) £ 6.75
• Set of AE camshaft liners/bearings for 998/1098 (AEC3046) £ 10.00
• Set or Glacier/Vandervell mains shells for PRE A+ 998/1098 (bought from MS but now they have changed supplier and part number, but interchangeable with AEM3314-00) still in the plastic wrap however corners have some slight staining from storage I assume? £ 15.00
• Quinton Hazel type inner driveshaft couplings, roller bearing type to replace rubber joints (QL5000) £ 40
• Set of handbrake leavers and boots (SMN10005 + 17H7612) £ 16
• Oil temp sender sensor (Transducer) for 97on MPI (YCB100320) £ 15
• Standard 998/1098 throttle cable for HS2 and HS4 £ 2.50
• Set of front hub seals to do both sides of car (GHS173 x2 and GHS101 x2) £4.50
• Moprod SU type electric fuel pump. Plastic bodied so wont go rusty. Tested and working. £ 45
• NOS (came from a 60’s car parts shop) brake adjusting spanner £ 5
• Set of door card blanks in fibreboard for making your own £ 15 (collection only don’t think I have anything to send these in).
Used parts
• Dip/Dim relay (pink bodied) Tested and working £ 12
• 2x single cable handbrak adjusting nuts £ free
• Boot lock mechanism (just the mechanism only) £ 5
• Grey standard seatbelt latch/stalk £ 8
• 998 top hose £ free
• Stainless roof finishing strip cover (genuine rover part) £ 4.00
• Aven England body file holder and double sided file £ 20.00
PHOTO HERE: http://i1255.photobucket.com/albums/hh622/...zps057302cb.jpg
Edited by retro-racer on 24th Jan, 2013.
kappa
Member #: 9854
Hounslow, Middlesex
Will the SU type fuel pump work for a 1275 turbo set-up?
If so I will take first dibs on this
Edited by kappa on 24th Jan, 2013.
retro-racer
Member #: 7907
Thame, Oxfordshire.
I don't think it will It is just a replacement for the SU type pumps on the early coopers etc. I don't think it will deliver a high enough pressure.
mossy2a
Member #: 9751
Derbyshire
Pm'd
NICKYBOY
Member #: 10438
Oil temp sender sensor (Transducer) for 97on MPI (YCB100320) £ 15 do you still have this part for sale????
NB
Member #: 10097
since it's been bumped, i'd take the main shells if they're still going.
