Home > Help Needed / General Tech Chat > Rear seat belt mounting plates on the C-post
Can these be removed?
Do they add alot of strength?
Can i remove them and seam weld the pannel joints and leave that area free from metal or should i sort a new light weight pannel for there to replace the original?
Car will have a weld in cage with ties to the front towers and rear turrets.
Cheers paul
ps i have searched but could only find about harness mounting points
Im sure this has been asked before but i cant find the thread either..
With a cage i would remove it, imo all it adds is stiffness and the cage likely replaces that
Only the late (~mk4>*wink* shells have those
Yep. My shell doesn't have them (78), so they can't be that important.
Wicked, they look heavy! Goo to get them gone then hehe. Starting to get more difficult to take much more weight out of bits now. Only 7 places left on the shell now
Can I have them once you have removed them?
Yes you can, it maybe a month through i have alot on this month with wedding, morgage, fixing car ect. Did you want the full pannel as in drilled spotwelds or just the inner section cut out?
If you cut cut them off close to the window lips that would be smashing. Obviously I'll cover post and some beer vouchers. There's no mad rush. They are more for inspiration for something else...
