| Home > Help Needed / General Tech Chat > honing (850) | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
28th Jan, 2013 at 08:14:17pm
hi
28th Jan, 2013 at 08:19:59pm
If there is no pitting in the bores you will need to measure them for size and roundness and check that against the specifications I seriously doubt it! |
28th Jan, 2013 at 08:37:17pm
On 28th Jan, 2013 paul wiginton said:
If there is no pitting in the bores you will need to measure them for size and roundness and check that against the specifications you can do anything if you set your mind to it...
28th Jan, 2013 at 08:42:26pm
If you havent already stripped the engine just run it and see how it goes I seriously doubt it! |
