Home > For Sale > 1975 Mini Shell with highest spec Safety devices multi point bolt in cage
pooler70
Member #: 7657
Hello all,
I am selling this mini shell. It is in very solid condition with the only work needing on it is a new drivers side a panel. I am selling the shell with front screen and cage fitted only. No other parts will be on the shell.
Is a very very solid shell and perfect for any conversion or to swop your bits over to this one which was my original plan.
Miglia style bulkhead, rear boot floor removed, can supply a carbon fibre item at cost. Rear arches tubbed. Full safety devices multipoint bolt in cage (approx £1000 new) with all the hard work of fitting it done to a high standard.
Poor pics at the mo as shell is in storage but it speaks for itself.
Shell and cage ONLY.
Located in Bristol.
Can deliver depending on distance.
£1500.
It looks tidy, if this is accedent damage is there anywhere else effected?
pooler70
Member #: 7657
There is no signs of accident damage on the shell. It is very straight and clean. Just needs a drivers a panel.
dev 11
Member #: 9393
stoke on trent
pretty sure that was gregs car wasnt it?
edit: yup
http://www.turbominis.co.uk/forums/index.p...tid=7180&fr=150
Edited by dev 11 on 29th Jan, 2013.
pooler70
Member #: 7657
edit: yup
Yes it was.
pooler70
Member #: 7657
Will listen to offers
t@z
Member #: 452
Chester, UK
i've not had my medicine today so excuse my ignorance but doesn't that price seem a bit... well on the high side. i'd want at least on shitty wheels and sus for that mula
www.twitter.com/lilpinkiy
pooler70
Member #: 7657
Well the cage costs approx 900 new and is a solid shell which seem to fetch around 500 so with the amount of work involved with fitting one of these cages i thought 1500 was reasonable. Make me an offer like i said if you think its too high.
Edited by pooler70 on 4th Feb, 2013.
t@z
Member #: 452
Chester, UK
On 4th Feb, 2013 pooler70 said:
Well the cage costs approx 900 new and is a solid shell which seem to fetch around 500 so with the amount of work involved with fitting on of these cages i thought 1500 was reasonable. Make me an offer like i said if you think its too high.
my SD cage which is very similar to yours (double door bars and centre roof bar, minus the double fixed rear as i only have 1 fixed. However that only cost me 350 second hand. I'd say realistically given the damage and the fact its not rolling maybe 600-700 max is more reasonable if it comes with v5.
btw just trying to help you out as you could be with that for a while at that price
pooler70
Member #: 7657
The cage is the bolt in multi point cage which ties into the front bulkhead area also and I think is worth 700 on its own as they never come up for sale 2nd hand.
What damage?? There is no damage.
Of course it is for sale with its original V5.
I understand you are trying to help but there is another shell on here for sale for more than this advertised price and I dont see you helping him?
1500 is a figure out the air. I am open to sensible offers like I say.
t@z
Member #: 452
Chester, UK
Furry muff mate i just happened to stumble on your thread as you bumped it.
sorry by damage i mean this; whatever you consider it to be i dunno
if the cage is worth that much personally i'd take it out and sell separately. Shells are always hard to shift as people on these forums already have minis :)
anyway mate just trying to help out and regard to the other thread you speak off i cant see his piccys at work and the fact its still for sale well; i guess you said the answer in relation to why i commented on this :)
Edited by t@z on 4th Feb, 2013.
pooler70
Member #: 7657
Yes a replacement A Panel is needed due to corrosion.
Yes I take your point. Would just be a shame as a lot of work has gone into fitting the cage with plates and captive nut inserts on the pillars etc.
I will see if any interest as a whole and if not will split it and get it on ebay.
Cheers.
kappa
Member #: 9854
Hounslow, Middlesex
If you decide to split, give me a shout, may be intresed in the cage, depending on price *wink*
pooler70
Member #: 7657
Open to offers. I have no use for shell or cage so let me know what you want to pay.
05bwardl
Member #: 9991
lichfield ,staffordshire
would you be able to deliver to near birmingham, what would the cost be ?
pooler70
Member #: 7657
PM sent
pooler70
Member #: 7657
BUMP.
£1000. Need the space.
