| Home > Help Needed / General Tech Chat > Help on engine build | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
30th Jan, 2013 at 04:37:14pm
Hi all,
389 Posts Member #: 9751 Senior Member Derbyshire |
30th Jan, 2013 at 04:53:12pm
Rod caps on the right way round? |
30th Jan, 2013 at 05:01:20pm
I just asked my old man this, he said yes, but going out to double check this now |
30th Jan, 2013 at 05:04:25pm
Recheck torque settings as you were just asking about them on a different threat. Do you have the correct size bearings in there? We had this once with a bent crank. Torque them up one at a time cheking that the crank still turns between each one... |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
30th Jan, 2013 at 05:17:38pm
sounds silly but are the main caps the right ones from that engine?
30th Jan, 2013 at 05:20:45pm
Undo the rod's and main caps one at a time until it spins, that will tell you where the problem is. On 11th Feb, 2015 robert said:
30th Jan, 2013 at 05:28:29pm
I'd take it back to the start; torque up the mains and check and then go onto the rods; if there is any one particular issue, it should hilight itself pretty quickly - all basically back to front from What Andy has said.
30th Jan, 2013 at 05:32:21pm
Also make sure you have no crap between the rod/block and the bearings On 11th Feb, 2015 robert said:
30th Jan, 2013 at 05:38:21pm
On each big end, grab each bolt nut with finger and thumb. Wiggle the big end back and forth on the crank. If it moves its fine, if it doesnt, its got the wrong cap or the cap is on back to front. if there is more than one tight, chances are the rod caps are all mixed up.
30th Jan, 2013 at 05:42:01pm
Right so I dismantled it all again, and re-fitted it all.
30th Jan, 2013 at 05:49:41pm
are we just talking about ring friction here?
30th Jan, 2013 at 06:18:37pm
Turning all fine now, only when I turn the first go, its a bit hard, then turns over nicely.
30th Jan, 2013 at 07:01:29pm
On 30th Jan, 2013 Sprocket said:
are we just talking about ring friction here? Sig'd On 11th Feb, 2015 robert said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
30th Jan, 2013 at 08:04:43pm
are we just talking about ring friction here? Sig'd On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
30th Jan, 2013 at 08:12:51pm
are we just talking about ring friction here? Sig'd I aim to please
30th Jan, 2013 at 08:13:59pm
It did read as though it was a little deliberate, but why not.. On 11th Feb, 2015 robert said:
30th Jan, 2013 at 08:23:56pm
No deliberation involved. It was a serious question on a serious subject On 26th Oct, 2004 TurboDave16v said:
30th Jan, 2013 at 09:03:24pm
This is quite funny, gone from a serious question to jokes |
