Home > For Sale > Big spec n/a head
bakker110
Member #: 9367
Derby
For sale is my cylinder head. It made 100hp at the flywheel on my 1293 engine.
It is an 11 stud 12g940 casting with 37mm inlet valves and 31mm exhaust valves. It has 21cc chambers as massive porting work at the rear. The inlets are as big the large bore gasket holes and the exhaust ports aren't much smaller. They look really smooth in to the combustion chambers. This is a really nice head. It also has the 180lb double valve springs.
I don't remember where the work was done but you may be able to tell by looking at the rest of the markings. I think it has BPCR7ES plugs and is unleaded. It has all the angled valves seats etc that would be expected on a head from this spec. I can imagine it compares roughly to CLUBMAN OFFSET RACE HEAD by MED which is nearly a grand.
This is not for turbo use but N/A
I'm after £475 ono for this plus postage or collection from Derby
Edited by bakker110 on 2nd Feb, 2013.
bakker110
Member #: 9367
Derby
Sold
WRLondon
Member #: 8636
Surrey
Have a similar spec head for sale
12g940 double valve springs HUGE seated valves
28cc chambers and flowed inlet and exhaust chambers
Reading up on RTS Clutches
