| Home > Help Needed / General Tech Chat > Engine will not turn over by hand (no plugs fitted) | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
7th Feb, 2013 at 07:10:40pm
Hi All,
7th Feb, 2013 at 07:15:04pm
scrub that, mis read the post,
Edited by Joe C on 7th Feb, 2013. On 28th Aug, 2011 Kean said:
7th Feb, 2013 at 07:34:27pm
you should be able to change gears and certainly find neautral by putting a screwdriver through the roll pin hole on the selector rod at the back of the gearbox and moving it. id depends what you mean the head is fitted loosley - you will struggle to turn an engine over by hand with the head on it. |
7th Feb, 2013 at 07:58:12pm
I have just taken the head off now, checked that the gearbox is neutral, by fitting a gear linkage on and gear lever and made sure its in neutral. Still no joy |
388 Posts Member #: 442 Senior Member Manchester |
7th Feb, 2013 at 08:51:00pm
Did you have the cam cover and assembly on when you tried it the first time? Dizzy drive assembly? |
7th Feb, 2013 at 09:09:33pm
Yeah the cam cover, timing chain and timing chain cover are on |
7th Feb, 2013 at 09:33:44pm
Have you been ale to turn it over since fitting the timing gear ?
7th Feb, 2013 at 10:19:35pm
No I cannot since the timing gear is on, I have not fitted the flywheel housing, so no clutch or pressure plate fitted |
7th Feb, 2013 at 10:55:30pm
Have you by any chance fitted a duplex timing chain ? If so did you fit the countersunk bolts ? |
7th Feb, 2013 at 11:00:58pm
I have fitted a duplex chain, when you. countersunk bolts? Where do you mean? |
7th Feb, 2013 at 11:02:30pm
I fitted the standard stuff that was on.the simplex chain |
7th Feb, 2013 at 11:15:27pm
There's your problem then.
8th Feb, 2013 at 07:36:33am
Thanks a lot Phil, I will do this and get it rectified, I owe you a few beer tokens
8th Feb, 2013 at 08:50:28am
Also - not being funny - but countersink the holes in the metal plate.
8th Feb, 2013 at 10:20:01am
Non spacer drum brake screws or cut down spacer drum brake screws also do the job On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2013 at 10:47:41am
thanks a lot guys the picture really helps, do I need to the same for the camshaft bolts |
8th Feb, 2013 at 10:54:16am
8th Feb, 2013 at 11:03:02am
excellent cheers guys |
8th Feb, 2013 at 11:22:03am
You also need to threadlock the countersunk screws in place to stop them working loose.
8th Feb, 2013 at 11:26:21am
Rod has that engine pictured been on the bottom of the sea?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Feb, 2013 at 11:43:12am
Thanks a lot Tom, Phil stated I need to remove the bump in the timing cover as well, does anyone have a pic of this, that I can visually see? |
8th Feb, 2013 at 11:46:14am
Bray this (from the inside) with a hammer so its flat
Edited by MikeRace on 8th Feb, 2013. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Feb, 2013 at 11:47:04am
Reight Bray up!!!!!!
8th Feb, 2013 at 11:53:08am
Excellent that is great, thanks again for the advise guys |
8th Feb, 2013 at 12:16:50pm
On 8th Feb, 2013 MikeRace said:
Rod has that engine pictured been on the bottom of the sea?? It wouldn't surprise me knowing the person I bought it from... But in reality it hadn't been run for 18 years when I dismantled it (I wanted the crankshaft and the duplex gears) and had been in various damp sheds for those 18 years. Schrödinger's cat - so which one am I ??? |
