Home > For Sale > Fuel pump, MG Metro cam, Forged Pistons etc..
giallofly
Member #: 164
The Stig..
Newport Pagnell
Camshafts re profiled by ZS cams to MG Metro profile (not tame MG Metro turbo). £35 posted.
Turbo hi pressure fuel pump, genuine MG item. the thicker inlet has a male BF Goodridge connection, will supply a female BF to go with it. SOLD..........
TWO only Omega forged piston. used but still very usable as spares. 15cc dish. Often described as "Challenge" piston. Still on conrods, 1 cap missing. £40 posted.
1275 A+ crankshaft, My mate at Ilmor began some light machine work on it, STD STD journals, good nose end, light surface rust but a good straight crank. SOLD.....................
Largest water pump pulley, releases a few bananas at higher revs. SOLD.....................
Usual JF rules apply, first you to cough up gets the item. None of this 20 questions via SAF (slow as fcuk) PM then say you've changed your mind.
JF... *smiley*
Edited by giallofly on 8th Feb, 2013.
kappa
Member #: 9854
Hounslow, Middlesex
pm'd
john will take the crank off you buddy pm sent .....
Dark Angel
Member #: 8965
MIldenhall, Suffolk
If its still available, I will take the fuel pump. Sending pm now.
