Home > Help Needed / General Tech Chat > FIA Battery & Alternator Kill Wiring Diagram
Mike
Member #: 107
Sunny Sussex
i had one sometime but cant find it, anyone got one handy?
I'll have a look for you mike, I have it somewhere, I also need to wire mine up too
Me too.....
Also. Where should I take power to the fuel pump from? I'm fitting a separate switch.
I'm fitting a heated screen as well. Where should I connect that to?
fuel pump should be connected via two relays connected to starter switch and oil pressure switch, so pump is only on when cnranking the engine, and when oil pressure is there.
heated screen, should be ignition live, again with a relay
Edited by Jimster on 24th Jun, 2005.
