| Home > Help Needed / General Tech Chat > need 6 speed gearboxes supplier | |||||||
6 Posts Member #: 10294 Junior Member |
11th Feb, 2013 at 08:20:39pm
313 Posts Member #: 9367 Senior Member Derby |
11th Feb, 2013 at 08:39:27pm
What final drive do you have? |
11th Feb, 2013 at 08:47:06pm
No one currently manufactures a 6 speed box, and there were only maybe two who did, Jack Knight and Tran-X, but I'm sure KAD have been there and done that as well.
Edited by Sprocket on 11th Feb, 2013. On 26th Oct, 2004 TurboDave16v said:
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
11th Feb, 2013 at 08:47:33pm
you will need some serious money for that sort of kit |
11th Feb, 2013 at 09:00:11pm
Just change the FD.
In the 13's at last!.. Just |
11th Feb, 2013 at 09:00:24pm
Are Jack Knight still trading? 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
11th Feb, 2013 at 09:47:39pm
Yes i use a 2.9.with 13 inch rims. plenty of top end there, a bit slow off the mark with the sc close ratio set i have. But the tall fd holds the car in the power band ie 3-5k for longer, and it pulls nicely with the torque the turbo gives in this power band. In all it flies when its got going with plenty of top end plis can be driven on the motorway at 70 plus without the turbo kicking in (t3) |
11th Feb, 2013 at 10:47:26pm
On 11th Feb, 2013 chinlesswonder said:
Are Jack Knight still trading? |
12th Feb, 2013 at 07:52:34pm
12th Feb, 2013 at 07:57:48pm
If your stuck with the final drive then you could go for some over driven drop gears to make it effectively a 3.1:1, loss of acceleration could be offset with a little more boost On 7th Oct, 2010 5haneJ said:
12th Feb, 2013 at 07:57:52pm
Can these be fitted with a standard crown wheel or are you limited by the LSD? |
831 Posts Member #: 908 Post Whore gateshead |
13th Feb, 2013 at 02:56:23pm
why do you want a turbo'd mini to go nice on the motorway??? just buy a cheap diesel! balls to the blower!!!
13th Feb, 2013 at 03:44:28pm
As it happens a 4th gear or 0.804 and a 3.44 diff is the same as a 1:1 4th and 2.7 diff.
13th Feb, 2013 at 08:09:51pm
I thought up your proposal and will be take the best solution maybe change final drive
3 Posts Member #: 10306 Junior Member |
14th Feb, 2013 at 09:18:52am
Hello, I'm selling a JKD 5 speed straight cut gearbox for a client who stops his project.
1 Posts Member #: 10421 Junior Member |
2nd May, 2013 at 05:51:33pm
I've got a 6 speed Jack Knight Dog Box with only 2000 Road Miles on it (no competition use) that I may sell at the right price. |
