| Home > Help Needed / General Tech Chat > wastegate | |||||||
![]() 517 Posts Member #: 9931 Post Whore brighton |
11th Feb, 2013 at 09:49:10pm
hi all this may sound quite stupid but what will I gain/ loose by adjusting my wastegate as its booked in for the rolling road on wensday, I have so much lag it's stupid haha |
11th Feb, 2013 at 10:13:24pm
Do you mean adjusting the preload on the actuator? If so adjusting will cause the engine to run more or less boost so make sure that the engine will cope with what you set it to |
11th Feb, 2013 at 10:20:09pm
Yeah the engines built to take a good 20 psi or so forged omegas stage 3 head etc if I adjust the preload will I loose a little bit of lag or not ? |
![]() 293 Posts Member #: 10010 Senior Member Northants |
11th Feb, 2013 at 11:01:14pm
That would depend on why you are getting lag, it will only help if the wastegate is opening before it should. But that is not really lag, thats it just bleeding off boost at lower levels than it should. If you put up specs of the engine and turbo and say what kind of rpm you normally get boost at people will be able to tell you if there is anything amiss with your set up or if you just have a laggy set up |
12th Feb, 2013 at 02:38:00pm
its 1293 with omega 18cc dish slark stage 3 head kent turbo cam enlaged turbo elbow rebuilt t3 with 360 thrust std rockers and running lucas dizzy
12th Feb, 2013 at 03:34:14pm
i think first of all we need to work out if your talking 'lag' or actual lag...
Yes i moved to the darkside |
12th Feb, 2013 at 04:26:13pm
Is the T3 a metro T3? What boost are you running and at what RPM are you making full boost?
http://www.twin-turbo.co.uk
12th Feb, 2013 at 04:26:57pm
Good post Brett. If something is worth doing, it's worth doing half of. |
12th Feb, 2013 at 07:38:25pm
On 12th Feb, 2013 Ben H said:
Boost threshold can be improved in many ways. Increase CR, advance ignition, different turbo, manifold design, etc, etc. yeah the list is virtually endless, cam profile, exhaust port size/shape, afr, air temp, exhaust downpipe dia, silencer design, even gearing and weight Yes i moved to the darkside |
12th Feb, 2013 at 10:35:44pm
Thanks Brett think I may of not known the meaning behind lag (oops) and its a metro t3 and for the down pipe it is 2.25 and I've had a straight through powerflow 2.25 system made with no boxes or any thing , I'm only running the std actuator 4psi bled out to 9 psi it starts at 3.5kand full at just over 4 thanks Charlie |
12th Feb, 2013 at 11:03:51pm
On 12th Feb, 2013 charlieb150 said:
Thanks Brett think I may of not known the meaning behind lag (oops) and its a metro t3 and for the down pipe it is 2.25 and I've had a straight through powerflow 2.25 system made with no boxes or any thing , I'm only running the std actuator 4psi bled out to 9 psi it starts at 3.5kand full at just over 4 thanks Charlie Sounds just like a normal Metro T3 then One thing I notice is the use of 18cc pistons, on a set up not too dissimilar to the standard Metro set up. What I mean is that the CR is much lower than the standard Metro with almost the same boost level. The addition of an intercooler only compounds it further. Put more boost in:) but still expect the Metty t3 to come on boost around 3500, that is what it was designed to do, is a physical property of the turbine size and the turbine and compressor housing A/R. If you want it to come on boost sooner, you'll be looking at the T2 or, the GT17 On 26th Oct, 2004 TurboDave16v said:
13th Feb, 2013 at 04:22:13am
Thanks Brett think I may of not known the meaning behind lag (oops) Not your fault mate it seems the whole car scene has grown up with it in recent times, there are a few other.words that get miss used too Yes i moved to the darkside |
13th Feb, 2013 at 08:51:10am
That boost threshold sounds a little high to me for a standard t3 on a 1275. But as you have lower CR it probably makes some sense.
Thanks Brett think I may of not known the meaning behind lag (oops) and its a metro t3 and for the down pipe it is 2.25 and I've had a straight through powerflow 2.25 system made with no boxes or any thing , I'm only running the std actuator 4psi bled out to 9 psi it starts at 3.5kand full at just over 4 thanks Charlie Sounds just like a normal Metro T3 then One thing I notice is the use of 18cc pistons, on a set up not too dissimilar to the standard Metro set up. What I mean is that the CR is much lower than the standard Metro with almost the same boost level. The addition of an intercooler only compounds it further. Put more boost in:) but still expect the Metty t3 to come on boost around 3500, that is what it was designed to do, is a physical property of the turbine size and the turbine and compressor housing A/R. If you want it to come on boost sooner, you'll be looking at the T2 or, the GT17 http://www.twin-turbo.co.uk
432 Posts Member #: 2726 Senior Member wakefield |
13th Feb, 2013 at 10:42:00am
Good luck today mate. :) |
13th Feb, 2013 at 04:10:55pm
well it did 121bhp with 0.6 bar boost but the fuelings way out :( at cruising its 0.68 lambda |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
13th Feb, 2013 at 04:46:38pm
Did they not adjust the fueling or was it just a straight power run? |
13th Feb, 2013 at 04:50:09pm
They didn't have any spaces so I grabbed what I could and tweaked it a bit whilst there, lambda on boost was .87 and afr on idle is 14.5 |
13th Feb, 2013 at 04:50:56pm
And yeah light power run |
