Home > Help Needed / General Tech Chat > brake pressure reducing valve (FAM7821) -> function test possible??
akirch
Member #: 399
Austria
Hello,
I have problems with bleeding my brakes, and in the meantime i am not sure if this thing works correct:
Is there a possibility to check the proper operation of this part??
Has anyone a drawing of the cross-sectional area?
Best regards,
Andreas
Edited by akirch on 12th Feb, 2013.
http://www.minifreunde.at
akirch
Member #: 399
Austria
In the internet most of the time i read to bin it, and swap for MS72 to control the rear brakes:
I do not want to take this route...
I have no idea how to test one, but they are known for seizing up. I plan to bin mine and put in a bias valve to the rears.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
could you explain how they work? is it just a basic 60/40 % type thing? or is more a regulator only letting a set psi to the back
asking as id like to get the best from my 8.4" vented mini sport for alu pots and rea single leading drums i think i have the bias valve thing mounted on the rear subby
Cables69
Member #: 10196
Yep the bulkhead mounted ones are notoriously bad, i run the one above on all mine, never have a problem and brake feel and are great
oli79
Member #: 8480
I did what wil said, worked great and much cheaper than the valve shown
Edited by oli79 on 12th Feb, 2013.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
I've got a wilwood proprtioning valve on my car which is almost a direct replacement for ye factory bulkhead one.
How much was the willwood though?
£60
http://compare.ebay.co.uk/like/261091646978
Get it from rally design for £60. From memory the post wasn't expensive and it arrived quickly.
It that the one though?
Oooo I like that. It's not what I was thinking.
http://www.rallydesign.co.uk/product_info....oducts_id=15436
*happy*
Andy that engine bay is too nice..l
It will be even better once everything is in it...
ntm1275
Member #: 9395
Andy - that a cool product
I've added it to my wishlist
Yo-Han
Member #: 3228
North of the Netherlands
On 12th Feb, 2013 apbellamy said:
http://www.rallydesign.co.uk/product_info.php?cPath=562_596&products_id=15436
*happy*
That looks so nice!
That's gotta be group-buy worthy....
Dazed and Confused....
Amp
Member #: 7856
Thread revival but is this still seen as a good solution or has there been any developments since? Price has gone up but is still still the best option? Has anyone had any issues using the Wilwood setup? Thanks
Edited by Amp on 17th Jun, 2020.
DILLIGAF
Member #: 9128
If you want to test the PDWA (pressure deferential warning actuator) thing on the bulkhead, disconnect one of the front brake pipes from one of the caliper. You should still get some braking effort from the other 3 brakes when you press the pedal. Obviously don't do this on the road/driving.
