| Home > General Chat > brake combos, with on without servo? | |||||||
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
12th Feb, 2013 at 10:12:48pm
Hello.
I popped my first one out the other day... |
12th Feb, 2013 at 10:19:02pm
They should be fine without a servo. My MS 4 pots run with a yellow duel circuit master cylinder are fine. Ok you have to press harder than a servo, but not stupid. http://www.twin-turbo.co.uk
12th Feb, 2013 at 10:31:50pm
im not worries about pressing harder, itl save me working that one at the gym, suppose the main question along with how it performs is what bits to buy to convert. On 17th Feb, 2011 apbellamy said:
12th Feb, 2013 at 10:34:45pm
http://www.minisport.com/mini-spare-parts/info_GMC227.html
12th Feb, 2013 at 10:43:58pm
i use a yellow tag master cylinder with 4 pots too love them Yes i moved to the darkside |
12th Feb, 2013 at 10:45:20pm
well this is all i need to hear.
12th Feb, 2013 at 10:55:10pm
The servo is for girls!! FACT On 26th Oct, 2004 TurboDave16v said:
12th Feb, 2013 at 11:02:53pm
If you wanted a servo couldn't you just convert to single line with a remote servo? |
12th Feb, 2013 at 11:08:25pm
On 12th Feb, 2013 Chalkie said:
If you wanted a servo couldn't you just convert to single line with a remote servo? He already has the servo But he doesn't really want the servo, why would he want to convert to a single line servo? On 26th Oct, 2004 TurboDave16v said:
12th Feb, 2013 at 11:09:55pm
I'm a girl, but not for much longer.
In the 13's at last!.. Just |
13th Feb, 2013 at 07:55:05am
Serves effect the pressure required to push the pedal. They have no effect on pressure that reaches the calliper On 11th Feb, 2015 robert said:
![]() 580 Posts Member #: 9580 Post Whore Surrey |
13th Feb, 2013 at 09:04:05am
7.9" vented ali miniSport 4 pots on 's' master and rear bias valve on racer work really well with no servo. Much nicer pedal feel than the road car running 7.5 's' brakes with late servo.
13th Feb, 2013 at 09:26:01am
i use minisport 4 pots with 8.4" vented rotors no servo and i blody love it! i feel i have more control without the servo as the line is fine between braking hard and locking up on bumpy roads
13th Feb, 2013 at 10:40:42am
I find left foot breaking without a servo much easier. With a servo it is easy to over do it. http://www.twin-turbo.co.uk
13th Feb, 2013 at 03:17:07pm
well parts ordered.
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
13th Feb, 2013 at 03:34:14pm
I've been thinking of ditiching the servo recently, mainly for more space under the bonnet but if it helps the feel of the brakes that's another good reason to do it.
On 13th Feb, 2013 Rick.SPI said:
well parts ordered. as usual tm come to the rescue, thanks all. :) http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
13th Feb, 2013 at 05:09:55pm
You need a none servo pedal box, or at least a replacement brake pedal as the pin hole is in a different place. Edited by apbellamy on 13th Feb, 2013. On 11th Feb, 2015 robert said:
13th Feb, 2013 at 06:10:28pm
aah bugger, ill have a look when it arrives and see if i can modify mine On 17th Feb, 2011 apbellamy said:
13th Feb, 2013 at 06:28:31pm
I have a non servo pedal box and potentially a spare pedal in the nimbus that I don't plan to use. On 11th Feb, 2015 robert said:
13th Feb, 2013 at 06:55:52pm
