Home > Help Needed / General Tech Chat > Crankcase breather
rjah321
Member #: 10140
Falkirk Scotland
Help I have dropped a washer down the engine breather hole at the bell housing end. Does this require an engine out and strip or is there any other way of getting the bugger out. Thanks
Jim
shellspeed
Member #: 9580
Surrey
On my A+ unit there is an elbow type shape cast into the clutch housing that turns though 90 degrees to vent the engine from above the drop gears. If your lucky you my get it out with a magnet. Other wise strip down, would not risk leaving it in
Could be worse, you could have dropped a washer in your spark plug hole...
lol!!
Jim
maybe not engine out, i have had the dropgear casing off before with the engine still in after killing an oil pump gasket, but 100% find that washer before starting the car
bahahahahaha
Edited by Brett on 14th Feb, 2013.
Get the washer out WHATEVER IT TAKES......or it will all end in tears,
rjah321
Member #: 10140
Falkirk Scotland
Got it it was still in the top part. A smaller finger with a dab of grease on it located it.
welshdan
Member #: 1111
s wales
The washer in the spark plug hole thread was a classic...
