Home > Help Needed / General Tech Chat > breaking the steering lock?
clubman_dan
Member #: 142
Winchester
i have FINALLY got round to ordering a towing eye to move my project mini to the lockup but i have lost they keys *laughing*
i have managed to open the door using the key for my girlfriends mini (a bit worrying, as it was as though the key was meant for that lock *indifferent* )
i need to break the steering lock now though and i am not sure how to do it.
its a 1975 mk3 so the ign barell is on top of the steering column and it only has the one stalk for indicators and full beam (if that makes any difference)
all help appreciaed, i need to get it moved its just sitting there and its doing my head in not being able to work on it :(
cheers
DAN :)
Doodmeister
Member #: 149
Alberta, Canada
Remove the cover then get a hacksaw to the gap between the two halfs and cut the bolts.
Dangerous
Member #: 417
Saw a slot in the bolt head top and unscrew with a screwdriver
nutter driver
Member #: 47
Not very sunny swanage
or drill a hole and use a screw extractor..... or drill a hole and hammer in a torx bit..... that works too......
bit of a dodgy thread really this.....
clubman_dan
Member #: 142
Winchester
cheers guys, :)
Mini_Andy
Member #: 432
does any1 know where i can get some blank mot's and tax discs lol
snowfruit
Member #: 557
Ireland
talking about removing the cover, I've had a really hard time getting the cover off my steering column. I've got momst of it loose, but there is something at the very bottom thats holding the top of the two halves together and I can't seem to get it undone... any help? I'd rather not break it....
nutter driver
Member #: 47
there is a screw hidden right at the very base of the shroud, cant remeber if its on top or bottom, but its definately there!!!
b16_b
Member #: 429
newcastle upon tyne
dont forget to take your masks off when you tow it from the house...lol
thiefs!!!!!!
snowfruit
Member #: 557
Ireland
thanks nutter driver I'll be looking for that :)
clubman_dan
Member #: 142
Winchester
its ok i will tow it at 1 inn the mornin and wear all black and a baliclava, no one will know *wink*
dan just make sure the brakes are up to scratch if you are towing it on its wheels, and it has been sat for some time.
clubman_dan
Member #: 142
Winchester
errm it doesnt have any brakes *indifferent* i was going to use a solid bar, or is it time to hire a trailer??
What you going to brace the solid bar against? Think all you will achieve is making a mess of your front panel!
It is just not worth the car coming adrift from whatever is towing it, and becoming a rollercoaster ride that you can't stop *surprised* *surprised* *surprised*
clubman_dan
Member #: 142
Winchester
ok trailer it is then !!
Either that, or just make the front brakes work so you can tow it?
Or one of those A-frame towing things that clamp onto both of the bottom arms might work?
clubman_dan
Member #: 142
Winchester
where abouts can you get these a frames from? and will a passsat estate with a towing hitch at the back be able to carry it?
Dangerous
Member #: 417
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...4555891487&rd=1
Loads on ere
