| Home > Help Needed / General Tech Chat > Banjo bolts for the GT1752 | |||||||
16th Feb, 2013 at 05:49:01pm
I apologise because I know this has been covered before but I an rubbish at searching.
16th Feb, 2013 at 05:55:56pm
M14 x 1.5 for coolant and M12 for oil. On 11th Feb, 2015 robert said:
16th Feb, 2013 at 06:00:23pm
I wouldnt use a banjo for the Oil drain, On 28th Aug, 2011 Kean said:
16th Feb, 2013 at 06:14:00pm
Can't see how you would fit a threaded return anyway, the hole is not tapped and is about 17mm across. On 11th Feb, 2015 robert said:
16th Feb, 2013 at 09:48:05pm
Senile old bugger got it wrong again !
336 Posts Member #: 9941 Senior Member Derby |
16th Feb, 2013 at 11:54:29pm
Just a quick question while we're on the subject what size are the threads in the small oil feed tee piece at the front of the block |
389 Posts Member #: 9751 Senior Member Derbyshire |
17th Feb, 2013 at 07:44:33am
Be careful with the oil feed, I'ts an m12 x 1.25 pitch, not the normal m12 x 1.5.
17th Feb, 2013 at 07:47:36am
Just to add, standard M12 is 12x1.75. The 1.5 and 1.25 pitches are both widely used and finer than standard.
17th Feb, 2013 at 08:29:12am
I just took the turbo to the hydrauuics place. no fook ups then. On 11th Feb, 2015 robert said:
