| Home > Help Needed / General Tech Chat > Swapping rear drum backplates | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
18th Feb, 2013 at 03:04:53pm
Hi, is it a problem to swap backplates side to side, so that the handbrake cable and brake pipes are up out of harms way on a rally car?
www.topcatcustom.co.uk |
18th Feb, 2013 at 03:14:01pm
You wouldnt need to swap them theyre the same arent they? You would just have to swap the cylinders over? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
18th Feb, 2013 at 03:23:17pm
I think they are handed- as the cylinders go at the bottom usually on both sides, and the handbrake mech hole is to the rear which means they are a mirror image, unless I am wrong?!! www.topcatcustom.co.uk |
18th Feb, 2013 at 03:48:51pm
They are Handed
18th Feb, 2013 at 03:55:31pm
It's ok- I don't think I can as the brake pipe from the slave cylinder is too close to the shock as it comes straight out, and I don't want to kink it by bending it so tight. Might scrub that one! www.topcatcustom.co.uk |
18th Feb, 2013 at 04:07:26pm
18th Feb, 2013 at 04:14:09pm
Doesn't it rely on having a flared soft metal end to seal between the pipe and cylinder? www.topcatcustom.co.uk |
18th Feb, 2013 at 04:35:09pm
The banjo fitting/bolt is sealed against the cylinder by copper washers.
18th Feb, 2013 at 05:05:46pm
putting aside the issues of making the brakes work (i'm assuming the shoes would need to be flipped about) what clearance will you have for the handsbrake quadrants off the floor?
Edited by Rob Gavin on 18th Feb, 2013. |
18th Feb, 2013 at 06:27:03pm
The orientation of the back plate makes no difference to brake operation as long as you put the shoes in the correct way.
18th Feb, 2013 at 08:28:21pm
I've fabricated tubular radius arms so makes no difference to me, as I have to weld on a couple of brackets to hold the pipework in place anyway. I'll check out the size of a banjo, if it's too tight I'll leave it standard. www.topcatcustom.co.uk |
18th Feb, 2013 at 09:21:38pm
On 18th Feb, 2013 wil_h said:
The orientation of the back plate makes no difference to brake operation as long as you put the shoes in the correct way. GTMs and my Nimbus have the backplate at 90 degrees (all be it on the front suspension). Handbrake cable is routed from above, so no quadrants needed. As it happens, I think it'd be lots of effort for no gain. It's all quite protected behind the wheel. Unless you run a crazy offset. |
18th Feb, 2013 at 09:40:52pm
Yes, it would be a very interesting route the cable would need to take to make it work. In and out of the boot.
