| Home > Technical Chat > Can exhaust manifolds be machined | |||||||
68 Posts Member #: 9818 Advanced Member Leeds |
18th Feb, 2013 at 03:54:02pm
I am about to install the turbo to my ERA. Checking everything over I came to the exhaust manifold. The centre pipe flange sits slightly out of line with the outer pipes, so when offered up to the head the outer pipe flanges sit on the head the centre one is stood off by 25thou. The surface of the centre flange is also a little pitted. The surface the turbo bolts to is also a bit rough.
18th Feb, 2013 at 04:04:49pm
The centre one always recedes. You can get them flatted off. If something is worth doing, it's worth doing half of. |
18th Feb, 2013 at 05:37:39pm
I had mine done on a surface grinder. If you do get the exhaust to exhaust housing faces done aswell.
18th Feb, 2013 at 06:29:09pm
If you're in Leeds, maybe Carl can help. Click Force Racing banner at the top. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Feb, 2013 at 12:14:09pm
Got it done at Lockside Engineering Castleford dead easy. All mating surfaces perfect.
21st Feb, 2013 at 12:28:20pm
how much did it cost? as i may be needing it done to some of mine too |
21st Feb, 2013 at 12:53:09pm
It was £40 that was both head side and turbo side.
21st Feb, 2013 at 01:29:20pm
M8. On 11th Feb, 2015 robert said:
21st Feb, 2013 at 01:53:59pm
The studs into the manifold are M10.
Edited by Tom Fenton on 21st Feb, 2013.
21st Feb, 2013 at 02:29:25pm
Just screwed a M10 onto it and it fits a treat. Thanks
21st Feb, 2013 at 02:47:46pm
http://exhaustpartsuk.com/index.php?main_p...04cadb2dc444df6 If something is worth doing, it's worth doing half of. |
21st Feb, 2013 at 03:10:34pm
That's great. Thanks, |
21st Feb, 2013 at 03:28:39pm
We're all here to help and to ogle at pictures of your sister. On 11th Feb, 2015 robert said:
