| Home > Help Needed / General Tech Chat > Dizzy Wiring | |||||||
21st Feb, 2013 at 03:02:41pm
Chaps, due to me having not wired a dizzy onto a mini for simply an age im having a bit of a spazzy moment.
21st Feb, 2013 at 03:06:10pm
Yes. if its ballast you will only get 9v at the coil. there will be a white/yellow wire from the starter which gives 12v on cranking On 11th Feb, 2015 robert said:
21st Feb, 2013 at 03:10:02pm
So do I need to wire in a new wire that gets 12v?
21st Feb, 2013 at 03:11:47pm
You may need to get rid of the ballast wire with the gold coil as they are 12v not 9v.
21st Feb, 2013 at 03:13:11pm
Whats the point of it? Does it stop interence with the Radio or summat?
21st Feb, 2013 at 03:19:04pm
No makes for easier starting.
21st Feb, 2013 at 03:19:54pm
Suppressed plugs/leads stop radio interference. If something is worth doing, it's worth doing half of. |
21st Feb, 2013 at 03:27:02pm
Stick 12v to the + on the coil as a work around to get it going On 11th Feb, 2015 robert said:
21st Feb, 2013 at 03:31:17pm
Sound that will do, ill cut the old wire back and tape it off and run a 12v from the ign.
